St33nXR
1 Neutral
  1. Hi I have just noticed a ticking sound, It seems to be coming from the back of the engine at the top, I have a ba xr6 turbo I did the hose thing and it sounds like it is above the mainifold I uploaded a clip of the sound to YouTube unfortunately Its dark I know it's hard to tell but could it possibly be a lifter or something? It's booked in to get looked at but won't be for another week I know my steering pump is cooked aswell that's the crazy buzzing https://youtube.com/shorts/QLtaPf51OyY?feature=share Much appreciated.
  2. Need to replace kinked cooler transmission lines from trans to radiator whats the best option cant find much online and need to sort it asap
  3. Yeah its got the black side stripe bit but I can get it painted cool so it'll be the same ill get it then cheers
  4. Would a ba xt mk2 rear driver's door fot my ba xr6 turbo mk2 got reversed into and need a replacement and that's the only one I've found near me cheers
  5. Gonna give the throttle body a clean and nah complete stock not even any mods yet
  6. Just started my ba xr6 turbo and it went straight to 2500 3000rpm and the check engine light was on then dropoed to an almost stall whole car shaking and wouldn't move in D (drive) but did move in reverse I turned car off and back in no light and engaged in drive fine no issue am going to book it in to a mechanic just seeing if anyone else has had tbis type issue
  7. I need to go for rego/blue slip and my new wheels havnt arrived yet that's all
  8. Cant really find it anywhere but is it allowed to run 17 inch on front and 18inch on back in aus/NSW
  9. St33nXR
    Need help
    Yeah I asked if they could make a duplicate key I thought it would of been coded and stuff I'll have to go back tomorrow if not I'll go and see a ford dealer or something cheers the help hopefully I can get it sorted just want my xr back and to be dosing everywherr haha
  10. St33nXR
    Need help
    Yeah it's the original bem and pcm from the car only thing that's now diffent is the dash and cluster it is from a non turbo ba everything else has not changed I got a new transponder key today from the local locksmith and when I do the pats reset it wont pick it up but picks the original up so I'm lost it thinks its been stolen should I go to a ford dealer? Or back to the locksmith because the key isnt recognized sorry for all this just dont wanna spend more cash if I don't have too
  11. St33nXR
    Need help
    Okay it was a NA I pulled the dash out of though so by the sounds of it its not gonna work at all?
  12. St33nXR
    Need help
    Alright I have the whole icc will just putting it be qs good or do I need to take it apart
  13. St33nXR
    Need help
    Ive just replaced my whole dash in my xr6t ba 2005 and im using the same icc and pcm but car will not start at all I even went and got a second key made (150 bucks) to-do a pats reset but the second key is not being reconized by the forscan software, security error is on the icc all warning lights are on the cluster I've tried everything but nothing seems to be working I'm most likely gonna have to send it to an auto elic any ideas are appreciated I'm sstuck and have put more money into it than I wanted too cheers
  14. Have replaced dash all wiring is done but car is now saying security code error I have the original ICC but not thw cluster due to it melting and it wont even crank all waring lights are on any ideas Cheers Also original pcm
  15. Yeah awesome wasnt sure if that would be a idea cheers will start the tomorrow
