MiKa
    3
Everything posted by MiKa
  1. Went for a proper drive tonight.. Wow what a difference, I was lighting up the road for the drivers next to me as well hahhaa... I hope I have adjusted them enough, no one 'flashed' me so I think I got it rite..
  2. Good movie man.. watched it a couple weeks ago, its wasn't what I thought it would be, let put it that way, but good movie, Liam Neeson is the man...
  3. Shy get Warrior if you haven't seen it.. Or The Inbetweeners movie for a laugh
  4. Yeah, I think ill go with the Philips H7 diamond vision at $50 off ebay, went to autobahn and they were over $100.. They Will be better then the std globes in there now and they are 5000K which shouldn't look too bad with the HID's, and got those LED parkers so it should look good once done.. Cheers guys..
  5. I rest for about 3 sometimes 4 days a week.. But try and keep the cardio up where I can.. Use to have up&go, haven't for ages..
  6. Thanks Dre.. Do you have the H7 HID's? How do you find using them?
  7. Anyone have a link for the parkers from ebay, the ten pack some of you guys were talking about? Dunno wether I should get HID H7's or not.. 1. I wouldn't use them that often 2. When I'd use them, it would most likely be to warn people about speed cameras etc. and the HID's don't like being 'flashed', plus till they warm up its probably too late anyway BUT HID's look awesome and now I can't justify spending more on normal globes to get the same effect of the cheaper HID's Was thinking about these http://www.ebay.com.au/itm/PHILIPS-H7-Crystal-Vision-4300K-Parking-Lights-/110750724293?pt=AU_Car_Parts_Accessories&hash=item19c941f0c5#ht_3609wt_1413 they come with parkers also..
  8. 1600dave, correct you explain it a lot better than I did lol.. Just went outside for a look, and the HID's stay on no matter the position of the stalk.. And yes the inner headlamps H7's? are the ones that'll need the warm up time, also they look really sh*t when used with the HID headlamps the yellow sticks out like dogs balls.. Might get that sorted tomo.
  9. Thanks Daniel, just need those LED parkers now to finish it off.. Also need new fog lights as the ones that came with the body kit are sh*t, I wanna HID them up too.. Also keen to get the h7's done.. Wenier, I had a muck around before I put the HDI's in.. headlights on, pull the stalk back and the headlamps stay on aswell with the high beams, but when I push the stalk forward to 'lock' the stalk in high beam, the headlight goes off leaving only the high beam lights on. So in order to not having the HID's turning on and off too quickly, I just have to pull on the stalk and hold it there when/ if I need high beams..
  10. Ok so dunno what happened to the pics, but they are normal on my comp??? If a mod could fix it that would be awesome LOL
  11. Probably one of the easiest things id done to the car, took like 10mins to install.. I have my battery re-located (nizpro kit) so access was not a problem. It isn't that dark outside yet so can't comment on how much more light there is, but I'm lovin the colour, very white with a hint of blue.. Took some before and after pics..
  12. Got my set today... H4 hi/lo 6000K $55 Gonna wait till later in the afternoon to install them so I can properly adjust them, might even get some pics... Is this correct. I read before that when I put my normal high beams on, the headlights turn off? So with this HDI hi/lo kit that I have as I understand it, when I turn on the high beams on a little flap moves and directs the beam upwards, but if the headlights turn off, I will have no lights all together, when using high beams, correct? By pulling the stalk towards me so it doesn't lock into the high beam position make a difference, with the headlights turning off or on?
  13. So is the ebay guy know what he's talking about.. Cause I wanna set, but I'm gonna ask him prob a million questions, cause I'm still not 100% sure what to get... So he's now in Mulgrave and you just go and knock on his door?
  14. Nick d.. That video is sick the a mount of fkn smoke.. That t sounded charged?
  15. Looks nice man... keen to know the details of the lights...
  16. F6 looks better, goes better, better motor, bigger injectors standard, bigger turbo, better brakes and being an FPV will hold its value better than an xr6T... but that's what you pay for over an XR6T, but... Better brakes= more expensive pads and rotors, if you damage the body kit they are friggin expensive for a new genuine one. Apart from that they are pretty similar maintenance wise.. Would I get the F6, hell yea.. Its faster in std form which being your first performance car, you'll be happier with it for longer, and WHEN you do decide to mod its the best base to start from..
  17. I was judging more by how much tyre is visible.. in the front you can't really see the top of the tyre, maybe that there isn't enough light there but it looks more tucked.. where as in the rear you can see the tyre clearly.. Either way, a tuff looking thing..
  18. Looks great mate.. The stance looks much better when your actually driving, as the arse drops that touch more... In the pics kinda has a hotrod ish look too it, low at the front and higher at the back..
  19. I think he's talking bout the mobile version.. the banner that appears at the top, never really noticed it till a couple days ago... If that's it, I haven't noticed a difference in speed?
  20. I was out last nite, not really much goin on, rain sux...
