Thanks for the reply mate,
The aftermarket parts don't really come with a specified bearing clearance as such..
Bit of a long winded reply here so excuse if it gets boring haha
I build engines for a living at a shop here in Brisbane, however every motor we build has a dry sump set up with an external oil pump so we send the bearings quite loose to survive... I don't build many street motors anymore and this is my first xr6 I have built.
The usual rule for bearing clearance is .001" per 1" of journal diameter(add .0005 for extreme boost/no2 applications).. this is accepted pretty generally...
This would put the barra mains somewhere around The .0025-.0026" and the big ends around the .0021".0022" for a std motor using this Formula.
looking at the barra workshop manual, they specify
Min/max clearance for the mains and big ends at .0007"-.0015"... that's insanely tight for a boosted application With the journal sizes it has!!
Is there a different workshop manual for boosted barra motors?
I initially built the motor and set the bearings at .0023-.0025" for the mains and the big ends set a little looser at .0025-0026".
However once started, the motors hot idle oil pressure was drastically reduced from the Pre rebuild pressures.. I guessed it was due to the extra bearing clearance and the oem oil pump just can't keep up with the extra leaks.
Cruise pressure seemed acceptable, however idle pressure had halved..
So I have torn it back down and will re do my bearings...
I was really more curious at to what other barra engines builders are sending their clearances at...
Thanks again guys.
