Lerm
  1. thanks mate will do, is there a chance ive blown the rear speakers in the process of jump starting the car? not too fimiliar with car audio and the shop I had the system installed at has shut down
  2. Hi, As of recent my rear door speakers are not working at all, I have 4 x Focal door speakers, 2 x Sound stream amps and 1 x Sound stream sub. Only has started happening since the car wouldnt start due to the clamps on battery leads werent secured properly and before I realised that was the issue I used a jump starter pack on the car and didnt turn over 3 times, even charged the battery but ended up getting the car started and now rear speakers not working, any help would be appreciated.
  3. Hi, I’m looking at getting these 20inch rims and unsure what diameter and offset to select for front and rear, also what size tires would best fit? I currently have stock suspension but will look into going SSL or SSSL later on and don’t want to roll the guards. Any help would be appreciated. thank you 🙏🏻 https://marsperformance.com.au/MARS-MP-T2-Gloss-Black-4x-20-Inch-Twist-Concave-Stag-Alloy-Wheels-Rims-5x1143
  4. Could it be one of those things if the sound happens when the clutch is engaged and disengaged?
  5. B
  6. It happens when sitting in neutral and taking off from what I can hear, the exhaust is too loud for me to hear if it happens while driving.
  7. Its a manual forgot to add that to the post.
  8. So I bought a 2014 xr6 turbo a month ago and for a while I had a rattling noise from the engine bay on idle and have just realised it also rattles when at low rpm (cant hear much at mid-high rpm due to the exhaust). I can really only hear the rattling noise when sitting in the drivers seat with the window down, I just had the idler pulley, pulley tensioner and drive belt replaced because I thought that was the issue but its still there. Any help would be appreciated as it doesn't sound good at all. Mods (all done by previous owner): 1000cc injectors 3.5inch turbo back exhaust with 4 inch cat and mid muffler delete fuel pump (unsure what fuel pump) 1000hp rated intercooler battery relocation/turbo side intake braided turbo oil line NPC twin plate clutch 1000hp rated tuned to 327rwkw
  9. Just an update, ended up getting DBA 4000 T3 slotted rotors and DBA street performance pads. Haven't noticed much brake dust but I do have black rims so its no issue for me.
  10. I've warped the stock rotors on my 2008 fg xr6t and wanna sus opinions on what rotors and pads people go for. I'm thinking of getting DBA T3 slotted 4000 series rotors but unsure on what pads to go for
  11. Bought a 2008 FG mk1 xr6 turbo almost a year ago and am now ready to start modifying it, just curious as what would be the best option to go with for an exhaust? Not looking for anything stupid load just want a little louder than stock with a nice tone and dont want a droning sound. Cheers.
