BarraT
1 Neutral
  1. Waiting your reply Caleb Let us know thanks
  2. Excellent Info Thanks If the fuel pump motor has been pulled out and checked and it isn't shorting to ground Then check your fan relays, they play havoc with the car electric system, when these fail, yes, true, you will notice the temperature rising in traffic, if the low speed fan isn't kicking in at 100C
  3. I have dealt with this issue in the past The relay shuts down due to a short circuit to ground Pull the pump, inspect / diagnose and if necessary replace .....
  4. They changed some parts across the 3 models, in particular : The oil pump The Front band friction The planetary gears Valve body Here is website addresses for part list identification https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/BTR_1994-02/ https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/BTR-ION-DSI/BTR_BA/ https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/BTR-ION-DSI/BTR_BF/ ...
  5. Sure, Yes, Correct, The BTR transmission was made here in Australia Your contact for BTR parts here in Australia is Driveline : Website address is https://drivelineap.com.au/
  6. Cancel that order mate Call Driveline for filter, oil and gasket (08) 8294 4342 Call MJ products for the cooler kit (03) 9702-4880
  7. swap the plastic connectors around, just push in the sides inside the holes and pull the connector off. Unclip the ear nose clamps, holding the existing hoses on and replace with an L shaped hose by Gates, Part number is 02-0025
  8. cant hear the noise your talking about it Check you didn't install your rear springs in upside down
  9. Let me know too Please !!
  10. Hey Caleb as a starting point you need Forscan 2.4, then Run a KOEO test and a fault code DTC scan before moving forward Have you checked your AFR and fuel pressure ?
  11. Have you pulled the Pump ? It could be shorting out Trace all the wiring back and check the connections at the pcm Check the fuse holder pins and the wiring under the relay box in the engine bay Check all the fuses under the dash
  12. Give simon a call from injectors online
  13. You will need to run Forscan 2.4, Run a KOEO and KOER Test, then check for fault codes and then data log items such as the 02 sensor to ensure it is switching, fuel trims, cam timing at idle, Check your power steering switch is operational, Check engine for air leaks using PID's IACTRIM & IACKAM3, Check fuel pressure and AFR, these are the basic starting points before changing parts
  14. Hi, how did you go to sort out the bad idle, Please post your solution to the problem for us in the future, thank you heaps
