Tony Thompson
1 Neutral
  1. For what it is worth, Barclays Radiator service in Wagga, who repaired my XR6 is a NATRAD agent. I would imagine they would all talk to each other.
  2. Eureka. Problem solved with aircon freezing up. As suspected, the Evaporator Temperature Sensor was faulty and once replaced all problems gone. Problem solved by Barclay Radiator and Aircon Service in Wagga Wagga.
  3. Thanks for the feedback OZY but in my first post I stated it had been playing up for 3 to 4 years from new in 2013. Then, last year I had it serviced in hope the problem would be rectified but to no avail, it did not fix the problem. I shall persevere and hopefully be able to let you know. Thanks again.
  4. I believe it is definitely freezing over as initially the aircon is working well and then I notice the airflow is becoming less and less from the vents until it ceases altogether. Last season I had the aircon serviced as I don't have the equipment anymore to do it myself as I have done for the last 45 years. After driving for a further 5 to 10 minutes the airflow gradually increases until finally, it is at normal volume. Just thought someone else may have had a similar problem. If I discover anything new over coming days I will let you all know.
  5. My 2013 FG XR6 has about 46,000 on the clock. For the past 3 to 4 years the aircon will cease blowing any air out of the vents after about 45 mins driving. Turn the aircon OFF on the dash and after about 5 mins the air starts to blow out the vents again. Switch the aircon to ON and cold air starts flowing again. I believe the evaporator is freezing over preventing airflow through it. I've checked and cleaned the filter behind the glove box and no debris. Any clues?
