To the OP, if you still haven't had the IMS conversion done or are looking for info I can tell you that the more solid the side/front diff bushes are the less clunk you will get. Like you, I have the manual but mines in FGX form. Mine's far from stock but has the CAT600 solid side bushes and Nolathane rear. Has obvious diff whine audible through the cabin as to be expected and slight clunk when selecting 1st or reverse at a stand still but no clunk at all when changing hard through the gears. The design of the diff mounting is such that the side bushes are responsible for the rotational movement of the diff. If these mounts are solid (or close to it) there is very little movement permitted, even under high load. This means the rear mount is not left with much flexing load, therefore the bolt should never snap. On the other hand if the side mounts allow a lot rotation the rear mount will be very 'busy' and in higher power applications cannot cope and will pass the load on to the bolt eventually resulting in failure. The IMS upgrade is definitely something I've considered and is a worthy upgrade for high power, drag racing etc but I have found that with the CAT600 side bushes I do not need to go that far. But remember there is always a compromise, the less NVH the weaker, the more NVH the stronger really.
