Tom Tucker
    28
Everything posted by Tom Tucker
  1. It's a good idea man. Not many people run them though. Falcons aren't meant to be tracked hard, especially not at 700kw. I was looking at a Setrab oil cooler, but haven't got around to it
  2. I've got the Castrol Edge 20w60 in mine at the moment. It boosted my idle oil pressure on idle to high 20s. The Penrite stuff is probably good to go.
  3. You might have to look at Force Performance in Toowoomba man. When I was in Brisbane, East Coast Customs did a lot of work on my car, and they deal with barras a lot. Not sure if they have a ZF transmission specialist though.
  4. I fitted a 4" Xforce. Not the easiest job in the world getting a 4" exhaust over the rear cradle. Lots of shops don't like doing it and will tell you only 3.5" is possible. Don't believe them.
  5. The Aeropro unit seems to be a good option. You just need to have it installed by someone that knows what they are doing. I like the idea of being able to choose whatever infotainment unit you want
  6. Yep, chucked in a high end Kenwood unit with Android auto, crystal clear reverse camera etc. Works perfectly with steering wheel controls.
  7. Installation of Aeropro facia, modified to accept Haltech CAN pad:
  8. Ok, got the Aeropro unit installed with a Kenwood unit (android auto, reverse camera etc). The facia has been modified to accept a Haltech 15 button CAN pad (coming soon). Will look sweet when it's all sorted
  9. Bit of momentum gathering to get her running again?
  10. I will one day. I've often wondered what the difference between a G40 and G42 would be. Lag in a manual is no fun, in my view
  11. Bit of an update. Still nothing broken. Pretty miraculous. It's going in next week to have an interior freshen up. Aeropro ICC replacement, new Polk speakers, rewire of some stuff. I don't really care about car audio because I'm always listening to the engine, but its all part of having this car super neat and tidy
  12. How did you go man? I did 6/4 brembos on the sedan. Obviously different, but no issues
  13. Fair point, I'll see what I can do. 0-100 will not be quick haha. It's been quiet on here lately...
  14. Managed to get out today briefly. Warmer temps in Canberra made a huge difference to traction. Managed to get 2nd and 3rd gear down, on the 3/4 setting (around 20psi, maybe 550kw or so). She's pretty quick when it hooks up haha. The G35-900 is pretty epic for a street driven manual. No waiting for boost, and still on like a light switch at lower load in 2nd gear, which is what makes it fun in my opinion.
  15. I've got the same injectors too. It should do 650kw easily
  16. Hopefully she's sorted! Looking forward to seeing results. You aiming for 1000rwhp?
  17. Ok, apologies for the delay. I've finished converting most lines to nylon braided PTFE, including the conversion to a fully billet thermostat housing. Much neater I think. I've retained the header tank for now, but I have a header delete top thermostat housing which I might do later down the track, but only with a radiator upgrade. Coolant temps are rock solid, so no issues.
  18. Yeah, you have to cut it and install the hardine to AN adapter. It was easy to cut with a little pipe cutting tool. Nice and neat
  19. Your water feed is probably at the front, so easy to access. Mine was routed around the back when the engine was out. The hardline underneath the intake manifold wasn't too bad, I just hope the AN to pipe adaptor doesn't leak...
  20. Ok, halfway through, but this should give an indication of what it looks like. I've retained the factory coolant overflow and just need to connect up the turbo water line. Easier said than done because mine's routed around the back of the motor. Bit of a learning process for me. I've also done full AN4 lines for boost control, but the AN10 lines for the coolant pipe under the intake manifold were a bit of a pain to make... the olive just didn't want to seat, and I frayed the braided line a bit trying to get it perfect. Anyway, looks tidier.
