Tom Tucker
    31
Everything posted by Tom Tucker
  1. Thanks lads. Looking forward to working through the next set of issues when I gets turned up haha. Loving the sound of it. 4" turbo back is brilliant, and I think the 4" vs 3.5" dump has helped bring it on slightly earlier than before. Hard to tell though, lots of changed made together
  2. Ok, here is a dyno graph from the run in. Zero timing, zero boost control. As you can see, it's very responsive. The valve train is noisy but the cams have changed the sound of the car by a fair bit. Sounds more JZish. Seems to have drastically increased fuel consumption too haha. The T-56 Magnum is super tight, it feels great, but the new twin plate is taking a bit to get used to. Time to put some kms on it...
  3. Yeah, those are the offsets. No issues with rubbing. They're pretty conservative fitment wise
  4. I've got 18x8.5 front, 18x9.5 rear RPF1s. They clear front 6 piston brembos, but the rear 4 piston brembos required a 5mm spacer
  5. Back to me this week to put a few km on it. Then back to tuner in Jan to send it. I've got a few small jobs to do in the meantime. IC-7 install for one
  6. I'll wait and see what the G35 does. Honestly, if it does high 500s with brutal low and mid range I'll be happy. The only way I'd go bigger is with a 4.11 diff ratio
  7. I've got the stock headgasket also. I don't think I'll be able to run much more than 25psi, due to the 1.01 rear housing and turbo shaft speed, but we'll see!
  8. Yep, very true.
  9. I actually think the most important thing for engine builds is genuine warranty and local workshop support if there are issues. Assuming you can't do it yourself like Puff
  10. Still haven't got the car back. But it's had a lot of work put into it, so hopefully all good. I've now learnt valve spring seat pressures are a bit of an art. Most people are used to just slapping in whatever, and aren't used to sorting issues when they arise
  11. Fueling issue? Fuel pumps/wiring? Pressure reg? Filter blockage? Injectors? If it's been sitting for a while, any of the above are plausible
  12. Oh, and the timing issues was a dead phaser
  13. So! Looks like valve spring seat pressure is responsible for the issues. Making the timing gear noisy until there is enough oil pressure in the top end. Super common apparently, and difficult to eliminate with stiff springs. They're only PAC 105lb with Ti retainers, but with the head machining, they have extra preload and are under higher tension. I have all Atomic HD timing gear, so should be ok.
  14. I'm a convert to full steel. But on my next engine build
  15. While I'm here... I uncovered a weird wear pattern on my oil pump when I got the engine built. Motor had billet gears installed into the stock housing, and the gears had etched a series of circular grooves into the cast side of the housing. Maybe some sort of foreign debris got between the gear and the housing. Or somehow the gear just started eating into the housing. New motor has new OEM housing with new billet gears and backing plate, but I can now see the virtues of complete replacement billet or steel units. The standard housing isn't great
  16. Its got to do with the performance of the cores and better fitment. The cheaper cores might be fine for what you want, but they invariably heat soak quicker than a more expensive core. Otherwise everyone would save money on cooler selection. Its got nothing to do with brand fixation
  17. 400kw on e85 is fine. On 98 not as fine but probably ok if everything is undamaged previously and maintained properly. Bit of detail associated with turbo frames, tuning etc
  18. Unfortunately, by the time you get custom piping done, it may be cheaper and easier to just go a full Plaz kit. Is it a cost thing, or availability?
  19. Apparently mucking around with cam timing settings is able to move the rpm of the sound. The brand new hd chain guide was changed out again as well because apparently it had a mark on it. And it has a new hd sprocket. Pretty much everything is brand new. I haven't actually heard it, I'm just letting the tuner work through it
  20. So, lifters and phasers replaced. Noise is still there! Apparently it is only at 2400-2600 rpm, and the noise point can be shifted with the Haltech. The guys are thinking it may be an issue with the Dyno-Mite cams
  21. Sounds serious! Love idea of a billet crank. I guess you may as well go all nitto rotating assembly then!
  22. So what sort of upgrade are you looking at?
  23. I wonder if you broke the crank, which in turn shattered your oil pump
  24. I thought cylinder pressure is a bit of an issue with the stock manifold over around 500kw?
  25. Yeah those Atomic ones look awesome. @JETURBO what's the plan for the ute?
