Tom Tucker
    31
Everything posted by Tom Tucker
  1. Morning all
  2. Actually getting some interior stuff done while the new motor is built. So stuff is happening, but not fixed yet
  3. Not just a full throttle run and dyno number print out? Actual focus on driveability? Not 10 other cars on the go, with a 2 week old apprentice doing most of the work unsupervised? You Sir, are selling the dream
  4. Yep, using a 4 port. Driveline = T56 Magnum, built single piece tailshaft, big driveshafts. It should take it, but traction will be the limiting factor. I managed to get it to hook up pretty well with 120TW Zestino semi slicks on the old setup
  5. Free boost? Why not 🤷‍♂️
  6. Full Darton sleeves going into a new block. Plus upgrading fire ring head gasket. Literally the only thing this motor doesn't have now it a billet block. It hurts
  7. Manual trans swaps seem to fetch $5k for trans, clutch, pedals etc. I imagine you could negotiate a 1:1 swap with someone, but wading through the dreamers will be tough. Lots of people seem to be opting for the ZF 8 speed swap these days. That's an expensive swap... The only other thing to factor is that it's a fair risk buying a used ZF. In principle, if you could find one from a wreck with low km maybe it'd be ok, but lots of worn out ones out there. And most people that get them reconditioned seem to have issues. I think your idea is sound. In Melb you could have a chat with Max Performance to give you a ballpark. They might even recommend someone else.
  8. Engine out. It will now get some interior stuff done while a new block is sourced and prepped. Bit of trimming, nothing crazy, but will go somewhere else in Melb for that, then back to IMS.
  9. Thanks for confirming. This will take a little while unfortunately. Was hoping to have news of 700kw by now
  10. My block isn't being repaired, it will be replaced. But apparently it's becoming more popular to prep blocks with only cyl 1&6 sleeved. Presumably those two fail most commonly, or maybe it has to do with water jackets on just those two?
  11. @Puffwagon ever heard of just sleeving cylinder 1&6? Apparently it's becoming more common
  12. Yeah, apparently it was just bad cylinder wall thickness. It's unfortunate that two machine shops didn't pick it up. But realistically, a small frame turbo setup will always be more vulnerable from cylinder pressure at lower rpm Apparently cyl 5 is most common. Followed by cyl 1 & 6.
  13. Confirmed. Cylinder 1 split. New block inbound, with better bore thickness hopefully.
  14. If it is it will be a new block. Anyway, we'll wait for the diagnosis
  15. Oh, sorry, meant back on the hubs. Nah, looks to be more serious. Engine coming out and being stripped down. Possible split bore
  16. So it was around 640kw at 24psi... Then a few issues appeared. Will report back when back on the rollers. Looks like it's where it kinda should be
  17. Ah, it's ok. I'm not too concerned about numbers on 98. So long as it goes ok and is reliable. E85 is for pushing limits
  18. Luckily I have E85 where I am, for now. But the United pump stuff never seems to be more than e80
  19. Definitely getting flex tune
  20. Apparently first start went well. Run in on the dyno on 98, easy 400kw. So it looks like it's where it should be. Hopefully some numbers next week
  21. That's not ideal. I luckily avoided a crash yesterday. Had a rain shower and someone must have leaked a bunch of oil or diesel on the road at a particular intersection. It was like ice, and a whole bunch of people ended up crashing into each other. So glad nobody ploughed into me. Sorry to hear you weren't so lucky
  22. Nothing much to report. How are things in Keef-land?
  23. Morning mate, top of the day to you
