Regany
1 Neutral
905 profile views
  1. Nah I dont have one mate
  2. Yeah me neither unfortunately 😂
  3. No I haven't changed the pcm And no I wouldnt fualt on the dyno at all, the car dosnt go into limp mode a warning light comes up and then I exit out of it and after about 10secs it goes back to normal
  4. Never happend untill after the tune it would not fault on the dyno and it did about 20 runs, happens in 3rd gear having the foot hard down. I do have a faulty steering alignment sensor but that's a separate system
  5. Has anyone had issues with fualt codes coming up saying software Incompatible with ecm/pcm and lost comunitcation with ecm/pcm only happens under full load and full boost then a warming light comes on and says comms error the boost gauge on the dash goes all the way up even at no revs, has only started doing it after the tune and the tuner has looked over the settings he put in and said they were normal and is not sure why it's doing it. The car is a 2009 fg f6. Any information would be much appreciated Thanks.
  6. Nah it still made 21psi but that was before the turbo was ported out but I'm not sure if hes checked it again yet, it cant be that hard to diagnose
  7. Yeah we have already bypassed boost solinoid so not sure what tuner Is going to try next
  8. Yeah well that's the problem living in New Zealand this is supposed to be a good tuner
  9. It's the factory turbo not gtx, was spiking to 21psi Was only making about 330kw at 4500rpm spiking to 21psi boost curve isnt very nice though staggers up and the fuel was rich as
  10. Waste gate definitely wasnt getting stuck we made sure of that and they have made sure the preload is right bloody pain in the ass
  11. We did that before we ported out the turbo and it spiked. next thing we are going to try is different springs but I doubt that'll change it the springs it has in it equal to 12psi but arnt the combination that are on the chart turbo smart give you as a combination for 12psi so I'm not sure if it's that or not
  12. Hi guys, cars been at the tuners for a over 2 weeks now the car is having a problem with over boosting we have taken off the turbo (3582r) and have got the turbo ported and new flapper but it's still boost spiking we have tried all the obvious reasons and have no idea why it's doing it the actuator is a 12psi turbosmart any information would be greatly appreciated cheers
  13. Hi guys, how much boost/kw can the stock f6 head studs handle when will the head start to lift? Cheers.
  14. Sweet mate cheers mate I'll let you know how I go after this lockdown is over in 2 weeks time hopfully wish I bought all the parts before hand only have the pump no wiring or reg
  15. Thanks for the info mate appreciate I've got a cousin that's a sparky I'll get him to help, do u have to modify the cradle quite a bit to get a 460 to fit ?
