Hede267
New Member-
0 Neutral-
Zf 6hp26 transmisson oil mix with water
Hede267 replied to Hede267's topic in Ford 4.0L N/A Discussion
hi 4321 do you know which sticker it is because theirs two , ones large and other is smaller . the large one matches with original but the smaller one doesn't ?- 20 replies
- auto transmisson
- zf6hp26
(and 1 more)
Tagged with:
Thanks for that kittens ???- 20 replies
- auto transmisson
- zf6hp26
(and 1 more)
Tagged with:
Hi there I wanted to discuss a problem ive had with my ford falcon fg 2009 with a auto zf6hp26 transmission after swapping with a second hand one , so me and a mate done the swap of transmissions and we swapped the tcm around aswel , now im getting a system coms fault and ive had a friend come in and scan it with a proper scanner tool and its saying it a shifter module fault ? he has tried to clear it but it just pops up again . has anyone had this problem or know the solution ? thanks in advance
- 3 replies
- shifter module
- 2009
(and 4 more)
Tagged with:
hi again fellas so I have swapped the old tcm onto the new transmission now the transmission fault code has gone just the system fault code still appears , my mate ended up getting one of his friends that owns a shop to use the scanner tool to scan and he is getting shifter module fault , hes tried clearing the code but just appears again , anyone might one what the issue is ? thanks in advance- 20 replies
- auto transmisson
- zf6hp26
(and 1 more)
Tagged with:
Transmission fault and system cons fault and definitely same tansmisson both fgs- 20 replies
- auto transmisson
- zf6hp26
(and 1 more)
Tagged with:
Hey fellas so me and my mates done the trans swap and now it wont start cause of the fault codes coming up can we attack that with a proper scaner tool or does it have to be sent into ford ?- 20 replies
- auto transmisson
- zf6hp26
(and 1 more)
Tagged with:
Cheers for that puffwagon definitely doing the trans swap this weekend after reading that story cheets ?- 20 replies
- auto transmisson
- zf6hp26
(and 1 more)
Tagged with:
Sweet mate will do- 20 replies
- auto transmisson
- zf6hp26
(and 1 more)
Tagged with:
Thanks for the comment keith , im definitely going to look into getting a transmission oil cooler . Im still gonna try flush and refill the trans oil till its clear just to see how the transmission is . Il definitely be doing the swap though thanks again keith !- 20 replies
- auto transmisson
- zf6hp26
(and 1 more)
Tagged with:
Oh really I wish mine was just as simple that mines getting very pricey lol cheers any way mate
Hey man I currently have the same problem, read my story I just put up and let me know if its similar, also check your trans oil and radiator for milky substance might be same as mine
Hi there im new to this but just wanted to discuss a problem ive had with my ford falcon fg 2009 with a auto zf6hp26 transmisson, so its my partners car and shes been driving it for a couples weeks noticing it making a werid rubbing sound now and then around 50-60km/h and now it got worse by it surging when in second gear in between 1-2 revs would rise and go down quickly , I took it to a transmisson specialist and he told me theres a 5% percent chance it could just need a service or its pretty much had it but he was pretty certain on it being done , now I myself like to work on my own cars other then paying thousands of dollars so I was going to do a whole transmisson swap so I got a hold of a second hand one in good condition and low kms for cheap . My friend told me to check the level of the transmisson oil so I took the filler plug out and very milky oil started bursting out . Firstly im thinking how is there water mixing with it and it shouldnt be so full so I let most of drain out till its at level with filler plug . I check my radiator water just to make sure and then theres milky substance in there aswel . It should be super clean cause I only just done a flush and fill on the radiator a couple months beforehand. I look online to find out where the water and oil are close together and I find out its the only part I know to my knowledge is the heat exchanger, so I go ahead and replace that with a second hand one I got with the trans and with the old one I try pressure the hose through the radiator input on the heat exchanger and block the output one to seen if water comes out of the oil lines . No water came out of the oil line so im guessing it must only happen when its under heaps of pressure and very hot if its not that then there must be another meeting point were the trans oil and water meet ? But any way I got rid of the milky water out of the radiator and topped it up with coolant and left the milky oil in the trans and took it for a drive it drove way better and stopped surging so I might try doing a drain and refill on the trans till it runs clear then service . But im only hoping it works . Sorry about the big story but itl be better if I said everything , if any one can help or give me tips on this il be greatly thankful as I dont much but trying and trying to do this on a low budget
- 20 replies
- auto transmisson
- zf6hp26
(and 1 more)
Tagged with:
