Slowxr6t
    8
Slowxr6t last won the day on December 7 2023
Slowxr6t had the most liked content!
69 Excellent
    New zealand
10,409 profile views
  1. Sheds are never big enough, unfortunately.
  2. Yea im slowly working that one out, they seem to be more of a problem than anything else. Do you guys know that the stock xr6t bov piston actually runs sideways so to speak so the piston cant actually be pushed open by boost pressure, it could potentially just leak past the o-ring that seals it when its shut. Not sure if other oem bovs work like that but it seems like a pretty good idea to me. Aftermarket should make them like that. I might chuck the stock one back on and see how it goes.
  3. I have a gfb dvx diverter/bov in place of the oem borgwarner bov that's part of the compressor housing and it has been working fine, well it wasnt opening under boost and causing a big boost leak. I was suspect that it could have been leaking and I had pressure tested turbo pipework and checked all plenum hoses and fittings and found nothing. I took dvx apart and put in a extra spring to make it really stiff and hard to open. It fixed it yaaa, I havnt had much luck with bovs on this barra, my Greddy type r 50mm leaked and when I put a stiff spring in it wouldnt open and this dvx has started to leak after a short amount of time too.
  4. Fair enough.
  5. @kenna802 whats wrong with 17 psi?
  6. Very noice, I forgot to mention to you before you built it, that sheds are never big enough, so make it big. Looks great though, wish I could come round for a dyno run in my barra.
  7. Do you aussies lay the concrete after shed is built? Otherway round over here pretty sure. Might be something to do with the scorching temps you get there and concrete setting too quickly and cracking?
  8. @Puffwagonmove to NZ, maxxing out here at 30 on a real hot day otherwise 24-26ish degrees.
  9. Iv heard its all in the tune.
  10. Turbosmart gave me a brand new replacement 50mm progate to replace my leaky one. Took 2 weeks but they came to the party, cheers ts. Iv put 19psi of springs in it and checked it with air compressor, reg and guage, its cracking open at 21psi. Im gonna try it and go to dyno, I want engine to boost 18-19 psi and hold till redline ish, it will be interesting to see how it goes, whether exhaust gasses start pushing valve off its seat early in rpms or not cos I still have stock 3 inch exhaust after the 4 inch dump but with screamer pipe now to relieve back pressure when full boost hits. I will update after dyno visit and boost control remap.
  11. On the up side you wont blow anything up.
  12. Feels like im posting to myself sometimes. Cheers keith for putting my post in here.
  13. Today I got fgx back together after mechanic mate and I supported engine, dropped sub frame, removed sump, cleaned it all up, new half moon seals, used loctite 518 as the goo of choice this time instead of threebond 1215. Removed a snapped sump bolt out of block, tapped a 8mm thread in block, cut all new 8.8 tensile bolts with 10mm heads to length and re-installed the sump. We made 2 studs to screw into bolt holes, one on each side in middle of sump to line the sump up correctly. Iv started car on hoist and had a good look around and so far no leaks, I hope it stays that way!!! Also my new turbosmart 50mm gate doesnt seal shut, at idle exhaust gasses come out screamer pipe, and yes its installed properly, iv taken it off car, and assembled with v band shell and clamp and you can see a small bit of light thru valve, I took it to shop I bought it from and he checked it all out and said we will have to send it back to ts to do a warranty claim. Pretty annoying cos I wanted to go to drags this wknd. Before I did sump I drove it with screamer and to start with its really obnoxious but the noise it makes grows on you and is really quite entertaining but still obnoxious haha, it puts a smile on ya dial every time gate opens.
  14. @Puffwagon merry christmas, im taking sump off fgx to reseal it hopefully properly this time, I dont want to do it again. So im gonna support motor from the top with my frame I made and drop the front subframe. Question is can I successfully remove and re-seal the sump back on with the zf still bolted to motor? Is Threebond 1215 grey still the go-to sealant or should I use hondabond or something else? Should I replace the halfmoon seal on the front of sump, I cant recall if theres a half moon seal at the back?? Im gonna make some threaded studs to thread into block to make the sump re-install way easier this time. Thanks
  15. Hopefullly your cp bullets are still ok except maybe 1 and you can re-use all your other high end expensive valve train, hope the head is still good, new rings and swap it all into one of your other good sonic tested blocks. With any luck another 2k barra. Sweet as mate, turn her down a few notches and it should last more than 10 minutes lol.
