Kanga
  1. I can't see this being a problem, car has been retuned with GFB BOV, Process West IC and custom intake. It's sucking better than a 50 yo hooker. Makes all the right noises too. 🤣 Yeah that's what I thought Camo, it should look pro enough to satisfy rego. The guy I use is a stickler now that he has been caught being dodgy. 🤣
  2. Thanks camo86T, that's a good point. I did manage to find one at Antzperformance and he has them on special for $145 so I thought that was cheap enough. CNC Laser cut and folded in aluminium, and powder coated in Satin Black. Come with all the bolts too.
  3. You're a mug, stick with the English lessons wâš“, "You do good, try hard, you be funny" !
  4. Does anybody have a template/measurements for CAI for turbo side (top & side). I'm a tight arse 🤗
  5. So, can anybody tell me how these bad boys would fit under the wheel arches of my FGX ? Diameter - Front - 19x8.5 - Offset - Front- 42.5PDiameter - Rear - 19x9.0 - Offset - Rear - 45.0P Easy/tight/fugeddaboutit ? There are a heap for sale on Gumtree in good nick from $700 to $1,500 a set of four with good rubber.
  6. Hi guys, I am now more confused ! I thought if a wheel had a 73.1mm centre bore it would fit my FGX. I.e. If I were to put those staggered Mustang wheels on with centre bore of 70.5mm I would have to get the rims centre bore machined to 73.1mm. Am I reading this wrong ?
  7. https://www.wheel-size.com/ show FG have centre bore of 73.1 Is this correct ?
