SelectivePC
    2
Everything posted by SelectivePC
  1. That would be pretty cool, I just got rid of a old Ford Ranger side step that I used for years as a Daily. And after trying to fit my current Barra project into the chassis, its going to take some metal moving.
  2. I would really like to keep a stock hood on it if possible. We have some ideas in mind to lower mounting points on the sub frame and space it down as well.
  3. Little update, still here....just stuck on the drawing board..... lol so as expected its a bit taller the oem stuff....but ideas are brewing and hopefully get it tucked down in the bay.
  4. I need to make my way down there one day and check out all your sweet new toys.
  5. Had this happen with a Nissan Murano here in the U.S. everyone kept saying it needed a new CVT trans.....gutted the cats and took care of everything. Saved $3600 for a $60 fix
  6. Hey hey now, my cheapy BA is going to be sweet.
  7. Finally started. Trying to retain the use of the Targa top. Soon....
  8. Thanks man, glad to see more coming to the U.S. and yeah anytime. Let me know ill PM you with my info. Properly prepped, time for some rocker boxes.
  9. A little more chassis prep, before starting on the cage.
  10. So the holiday weekend left me with lots of time to get some more prep work done. Surprised how much weight I was able to get out of it. But hopefully ill be in the 2800lb range once im done installing everything else. (cage and a BA barra) Wiki curb weights the car between 3200-3600lbs if it has a targa top, which mine does. But this is just motor, trans, front end tid bits removed. Sound deadener being removed. This is more like it. Now to keep it low.
  11. Not much, but its a start should turn out OK with some more practice of course.
  12. Now some practice with the welder, its been a while. But just like a bike, got it back down after a min or two. Starting blocking in the fronts for the front end.
  13. You have my PayPal good sir, do your worst lol!!!
  14. Still waiting on a way to get the guy to ship those larger spacers for the head. I have the ball bearings to raise the stud height, But I dont think he is going to ship them :(
  15. So learned how to use the plasma cutter today.....hmmm
  16. Thanks, its about to get real here soon. Just received a ton of material too start fabbing up some chassis stuff and the cage.
  17. So, just spent the last hour or two watching all of Atomic's videos, plus some other rabbit hole videos....looks like I have some work to do. :D
  18. Its stuff like this that makes me think you guys do the craziest stuff. I would have never of thought to do that, and I don't see why it wouldn't work.
  19. Ok ill have to take some measurements to tomorrow, and see what I can do about this. OK so, my only issue with this is the ARP studs are not going to be long enough either now. After measuring out all of their requested numbers, this is the stud that would fit, and currently the nut runs down level with the top of the stud.
  20. So today was a great day. Had some customers fall through, so had a bit of time today. Swapping the front sump girdle for a rear sump version. Re-torquing the main bolts. New rear main seal while im in there. And new rear mounted pick-up. Oil pan installed, and cross bolts with thread sealant. And finally!!!! The two together. ARP calls for 125ft. lbs, for the random bolts I had to order. Done and done. *Note to self, head bolts are not easily accessed with cams installed already, so small learning curve. Cams reinstalled. (Again) And started getting some timing ready to do, but enough for today.
  21. Sure if its not too much trouble, I'm sure its similar to the other inline 6 stuff I have done, but never come across the 2 girdle system the Barra uses.
  22. Some progress today on the head. Just need to find the proper torque sequence and specs, for the caps. With any luck should go back onto the motor sometime this week, and work of bolting it down and getting timing items on and re-timing the motor.
  23. Found a little time today too make some progress. Tapping oil galleys for NPT plugs, and the future oil feed Started installing new valve stem seals and upgraded crow valve springs Little by little.
  24. Nicely done man, I have finally my head back from the machine shop. Recently de-burred the rough edges from the decking process, and then drilled and tapped the oil galley passages for plugs, and re-assembled. Cant wait to start prepping the engine bay for fab work, but im still a few months out, I think.
