SelectivePC
    2
SelectivePC last won the day on October 1 2020
SelectivePC had the most liked content!
70 Excellent
  1. It is its currently, running and driving now. Just need to figure out how to post a video, or post it through YouTube I suppose.
  2. Ok, another update to the project that never stops. Big things have happened since the last update. Engine build was completed in June, and engine started in July. Once it was running I have finished most of the remaining fab work since then and now that wiring is complete the cage and going for paint soon.
  3. These were supplied with the transmission adapter kit, 10.9 on the bolt head so just a metric grade 8. Planning on using ARP stuff now that they are out, which ill be getting too in the next post, to answer your balancer question. So it happened, I talked to the engine builder and it is currently at this shop torn apart. He is extremely excited about this build too say the least. Took me 25 mins took disconnect everything with my buddies help, and load it into the truck. So time too prep for some paint in the bay, and powder coat the suspension stuff, while I wait. Wish me luck.
  4. So with this being the case, I have found a builder who is extremely excited about getting my Barra too start building the bottom end. Rods, and pistons. Your a tough sell @eff xr6t
  5. Oh yeah, it was going to be Turbo from the start. I'm wanting too see how far I can push it on stock rods. Once its running it will be getting a built bottom end. Then the real fun will begin.
  6. Yes once all the wiring is finalized ill be fitting the firewall with a appropriate mouser connector.
  7. MAJOR UPDATE: So, lots of little work as been going on, not much to post about by themselves, but as a whole its starting too look like a car again. Wanting to make maintenance a easy task, so keeping the motor set easily removable is the goal. Currently without wiring, and fluids this takes 15 mins. New manual brake portioning setup and pedal setup. Also seen there is the FuelTech550 mounted. Turbo setup mounted and mocked for plumbing. Side note* waiting on a new front facing plenum, so getting rid of the over the top setup shown here. Fuel Cell, and rear mount radiator mounted and ready for plumbing. Still need to mount the water pump, has a issue sourcing a pigtail and plug, but all is fine now. And Finally everyone's favorite. Wiring.... So yeah, that's about it for now. Until next time from across the pond!!
  8. Checking in from Florida!! It would be cool too see adapted. But how would you tune the trans a separate controller?
  9. So after a little research and going through the 600 plug Catalog Ford offers. I have matched the plug and it works!!! thanks for the ideas guys!! This is the greased version of the connector, there is also a non-greased version. Part Number : WPT-1361
  10. I could defiantly do that, but being the main water pump, I'd like to have to have it on a nice plug. I actually ordered the kit with pigtails pictured above, last night.
  11. I messaged both of the sellers I found online, neither of them are coming off the information. I think I may have ordered the wrong kit. Haha I may order the pump and wiring kit as pictured above, and return the pump only I ordered. Keep it simple
  12. I ordered this pump through a different company, the picture I posted, was found when trying to research the plug itself.
  13. Hello, kind of in a pickle with trying to ID a part number for a connector for a cobra jet water pump. Its used to pump the supercharger coolant. I am using it as a engine water pump. But when I ordered the pump it didnt not come with a pigtail. Has anyone here used one of these? Or possible know a part number for the pigtail. Attached are pictures of the 4 pin pigtail.
  14. Yeah, checking in from Florida here, I have done basically everything you listed, plus a mild port. But yeah SXES366, valve springs, OPG's and good fuel on a NA-T set-up. I'm hoping for 500 from my setup, But I have a forged bottom end ready and waiting, so I may just push it.... 😮
  15. Thank you sir, I over looked that lol.
