jdracing
  1. Thanks mate, similar position to the AUX plug I guess ? Have you used an OBD2 Scanner tool and if so any tips as I am new to this lol https://www.ebay.com.au/itm/OBD2-EOBD-Car-Fault-Code-Reader-Scanner-Diagnostic-Auto-Engine-Scan-Tool-Foxwell/192329517149 or https://www.ebay.com.au/itm/USB-ELM327-ELM-OBD-OBD2-Diagnostic-Scanner-For-PC-Engine-Scan-Tool-Code-Reader/151533914978
  2. Was thinking about purchasing a OBD2 diagnostic scanner tool and was wondering where the plug is located to plug it into on 2006 BF Falcon XR6 ? If anyone has any other advice on what they feel is the best one to buy or tips on how to use it etc would be greatly appreciated. Thanks in advance.
  3. I just want to clarify that for the first key you only turn it to acc and 2nd, 3rd keys etc you turn to the on position ? for the "To code additional keys:" process
  4. I purchased a new key online it is the flip key with the fob all in one for my BF XR6. How do I code the key to the car not the remote I can set that via the rear demister button I mean the actual key apparently needs to be coded ? The key cutting place I went to said there machine can read the code in the chip but it cant copy it, does this sound right as he said he could put 1 of his chips in it and code it chip $100 cut the key and code it $40
  5. I will try again as my previous post vanished I have 2 problems with the car and wonder if anyone has the fix ? XR BF Falcon 06
  6. Your a bloody champion mate
  7. Disconnect the car battery for 30 minutes, reconnect then turned the key to acc and press the rear demister button 3 times within 5 seconds of turning the key and the doors locked ( wow I fixed it ) then I pressed a button on remote 1 and the doors locked / unlocked and repeated for the next 2 then turned the key off all set. So basically to get the rear demister to function for this purpose again I just had to disconnect the battery for 30 minutes, this reset the system and allowed it to function as per normal again. Your welcome I have 2 problems with the car and wonder if anyone has the fix ? XR BF Falcon 06 1/ Headlights don't come on when set to Auto ? 2/ Boot light/luggage compartment light not working, globe is ok, fuse is ok and if the metal on the globe holder touches the metal om the car it sparks, so I can assume it has power lol ?
  8. I have 3 remotes 2 already matched I am not talking about coding a key it is training the remote
  9. I had 2 working remotes, but as I said it wont even do the locking sequence when I press the demister 3 times, so it's no longer doing anything.
  10. Hi I have a BF Falcon and I got another new remote and as I did previously last time I had to train the remote I took the same steps. close the door turn key to ACC then press rear demister 3 times within 5 seconds and the doors will cycle then press a button on first remote and so on, trouble is this time nothing happened when I pressed my remotes it did not train them and when I try to do the process of pressing the rear demister 3 times nothing happens so I cant train any of them as nothing happens when I press the demister 3 times it doesn't do the door cycle like it should.
  11. My car is doing the same, did you find the problem and how to fix it ?
