_RobynKennedy
2 Neutral
  1. Yeah dude if you read my reply to carl.hollway ended up giving it a punch and she's good for now, Thankyou though for your help no doubt other people have had or will have this issue and this thread will be of help so cheers!
  2. Yeah I did they're 15A and all good, apparently reverse lamp fuse can be a problem as they are on the same circuit but both mine were okay worth checking your reverse lamp fuse I'd say? I ended up banging it left hand side of the steering wheel where leather meets side of ICC and banged it a couple of times and it came through was so stoked hahaha. Try that and if that doesn't work my friend told me the white plug behind ICC might be slightly unplugged or something might be worth a go? Careful with that dash triangle though man they break so easily go from right hand side top corner of it unclip that clip and then run hands along it and there's another clip on the left side otherwise you'll be in for a new one they break extremely easily not an overly complicated unit to remove but watch a youtube video on someone else doing it always helps me. Also heard can be related to ignition barrel issues which is a c**nt of a job, excuse my french! No audio my friend and no reaction when I pressed any of the buttons mines come good for now must be an underlying issue though but my bush mechanic mate always said "if it's not broke don't fix it" so I think I'll follow his advice for now heard it can lead to car not running at all though scary stuff!
  3. BA ICC Unit issue, Stereo dropped out and aircon whilst driving and won't turn on or work when manually try to turn on ICC,blank screen and still no fan or aircon.... Things to check or anything suggested to rectify the problem?
