Red Tonner
1 Neutral
  1. Yes I still have the same e mail . My problem is I can not up load any puctures or videos .that was one reason I found face book so much easier . Just can not work it out, even asked some of the younger apprentice if he was able to .
  2. The disks look like they glaze up .it looses brake pedal even after using them hard only once .from 200 klm down to 100 klm . It has all been re build only about 6000 klm ago but for some reason the pedal goes to the floor and does not pull the car up . It also has braded brake lines . I thought it was the temp under tge bonnet that cooks the master cylinder as I am flat out putting my hand on it after a track event . The other theory I have is that the master cylinder might be leaking through the seals bit I do not loose any fluid . The brakes only need to be stood on hard one time and there is nothing . I had it at a brake place but they could not fault nothing . They were to buisy at the time to look at them with a test drive . I have also flushed the brake fluid 3 times with penrite racing fluid with minimal improvment . Thinking of maybe changing pads to some bendix as I orfered them first but the brake place gave me the ebc reds instead
  3. I have tried very hard to up load videos and pictures of my ute but can not work it out as we no longer have a computer after the last one we bought only lasted 3 month . So I am using a samsung 7 mobile phone .I have done what jet said to do but I can not work it out .thanks for any help .
  4. Thanks for the info jet .rim size is the standard 16 inch by 7 . The tyres are 255 50 16 . Mickey Thompson et streets say 7 inch wide is the smallest size I can fit them on . I marked the rim and wheel and noticed after the first time I went on the track that they moved by 50 mm . They then only moved another 20 mm but that could also have been a full rotation ? . Is there any mods like rim locks I could get fitted to them . Thanks for any help on this
  5. Yes its good to be back .had to change user name and email address to get back on here . JETURBO how can I stop the tyres from spinning on the rim , that is why I never droped the tyre pressure below 23 psi when hot . If anyone could help me with the easiest way to post pictures and videos . Thanks .
  6. Had to use a new user name , yes its Gunna .Only reason I did not post on here was I could never get back on here . And yes I have missed everyone especialy jet . He is a top blocke that is for sure . Took the ute to the all Aussie day at lakeside last sunday , and it went real well . Have done some small mods to the car that I never finnished before my work accident , and I find it very hard to work on my car now .the accident has changed my life for certain . Also Beau is living with us now for free as the buisness he started failed and he closed the doors , long story and its the past now . His kingswood we have in storage for a rainy day to work one it eventually when I get better . Ps he now has a permanent job locally up here . He is doing a lot better now .those new Mickey Thompson et streets work very well at rill racing but the 1/8 mile I had them pumped up to much at 23 psi and they spun on the take of and even up higher 3th gear . Still was faster than most I lined up against . This was the first time on the track and E85 tune for like 11 month No idea how to post videos or pictures sorry.have heaps
