greasemonkey
    3
greasemonkey last won the day on February 23
greasemonkey had the most liked content!
13 Good
  1. I don't think so but you can search at Alltranz. Was given this business from members of this forum and it helped me source exact parts for the zf6hp26 trans. I've put a link below for FG falcon trans but check your serial number on the box. Mine ended in 020. https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/ZF-by-Transmission/6HP26/
  2. The question was actually for anyone who may know. If you're implying I'm lazy mate, I take offense to that. I haven't had a chance to sit on my arse for many weeks due to car work! 😓 I fitted the shifter linkage on Tuesday or Wednesday. First time taking it off and doing so. I look at technical information and what I'm presented with is totally different from my car shifting when I test it. The technical material I have available doesn't give me what the ZF gearbox does. I can't find anything on the net either and I searched and searched. I assume with cars these days on small and bigger jobs that I'm wrong until I get verification on stuff. I've assumed in the past I've done stuff right and it usually blows up in my face.
  3. I'd already fitted the shifter on and far left is drive and far right is park. I had xr6tforme take some photos of the positions for drive and park and they match up which was all that I was after . The picture I put from the Haynes manual is the 5 speed box which I found out is based on a Ford C3 transmission. There linkage positions are exact opposites to our ZF gearbox
  4. I had a go of shifting from inside the car and saw that the linkage at the gearbox is actually the complete opposite direction of the Haynes workshop manual that I have for the 6 speed transmission. In other words, far left is drive and far right is park. The Haynes manual lists otherwise for the FG XR6. Which is correct?
  5. So I took the pan off and saw straight away that the plastic rod wasn't inbetween the selector linkage. It's a fairly simple design. I used the reference bulletin that I pasted above but it was a bit confusing as there is an additional part, specific for BMWs I believe. Anyway, I took the mechatronics out and bolted it back up. Hardest part was the mechatronics screw on adaptor plug seal, pushing the locking tab back out. I took the mechatronics unit out again because it felt stuck but it just requires some constant force upwards and then it clicked in. When I moved the linkage selector on the outside of the gearbox, it felt like it went into 8 different positions. What is the order. I'm guessing you have PARK at the very left, then REVERSE, NEUTRAL, DRIVE. What are the other clicks for or is the order for the ZF shift positions different? Why I'm asking is I have to set my shifter and linkage to be the same.
  6. I found this video on installing Territory rear brakes from a youtuber (Zac Baldy) who did something years ago changing his rear brakes on his XR6T.
  7. Puff, are you saying you need to pull apart the internals of the mechatronics including the PCB boards etc or just unbolt it? Just need to see what the position is for that shift linkage brown rod. Can' track down anywhere that has the position setting for that brown rod.
  8. Okay, that clears up what I thought that it doesn't matter with fluid levels. Do I have to take the mechatronic off to reset this linkage? Do you have a picture or some website where it shows what it should be set to visually. Is it meant to touch the brown cylinder little tab thing (the two sides wedge between each). Or is it not meant to touch but be as close as possible?
  9. I also found this just recently on a BMW forum with the ZF (7 series). My trans has no oil in it at the moment. They replenished oil in this thread and the trans then got out of park. However I am not sure if the gearbox from that forum in that thread is electronic compared with my manual shift lever ZF. https://www.bimmerfest.com/threads/stuck-in-park-after-changing-mechatronic-sleeve-and-seals.832479/
  10. Alright. So I hit a road block again. I have everything now bolted up and finally together. My last part was finishing to bolt up the rear drive line mount and then put the selector cable on for the shifter. When I installed the shifter cable, I noticed the selector bracket mounted to the left side of the transmission (not the shifter cable itself) is stuck. It is currently in the park position and I can't move it. I installed the shifter cable to determine if the shifter was not adjusted properly or something different with the transmission. The shifter is fine, the cable is fine. Unfortunately the selector linkage that sits on the left hand side of the ZF 6 speed won't move. How is this controlled within the transmission itself and why could it be stuck? Trying to think about what I pulled apart. That was the oil pump and part of the E-Clutch came out as it is behind the oil pump. However I pushed and seated the clutch back in which allowed me to install the oil pump correctly. Anyone have this happen before when installing their transmission. I don't want to have to take the transmission off for a 3rd time? I found this on the ZF brochure Puff uploaded: Would this cause the linkage plate that attaches to the shifter cable to be stuck and not be able to be moved???
  11. I figured I'd take as many photos as I can for those wanting to do it for the first time. Just so its as easy and straight forward as possible.
  12. So the transmission is all back in. This time, it went in very smooth once I got the transmission bolted on. The difficult part is getting it onto the jack. I saw a video of just using wooden blocks. Somehow on my first go, I actually did this, using many small wooden blocks stacked near each other to raise the trans. However it's a poor way of doing it. Had to figure out a better solution. I realised that I had little to no spread of force and tension across the bottom of the transmission with small blocks and my jack. So I made a wooden bracket at the back and front of the transmission using some M10 bolts from wood I had lying around the garage. It worked really well. One thing to note is you need to make the bracket at the back long enough that when you stick the transmission jack under, the supports aren't blocking the path of the jack to go under the trans pan. The photos may explain this a bit better. https://imgur.com/dGBzcyY To get the height I needed, I used some big pieces of thick wood. Originally they were going to be used as car raising blocks but they've come handy for many things. You can see the support at output shaft end. Just used two existing holes to bolt it up. Used the lower mounting holes on the bellhousing for the front piece as well. You get the idea. My original piece was too narrow and I made it longer by 15cm on each side. Front of car looking back https://imgur.com/undefined THEN JUST A MATTER OF GETTING IT HIGH ENOUGH AND THEN PUTTING A WOODEN BLOCK UNDER THE PAN TO JACK IT UP. ONCE THE TRANS IS SUPPORTED BY THE JACK, MOVE THE BLOCKS AWAY. You may need to have one hand around the trans to balance it a little occassionally but it should be good if you have at least most of the support covering the back 2/3 of the transmission. This time I used some threaded rod as a guide for the two M10 holes on each side of the bell housing to help line the transmission out. Once I had all the bolts in, I puts the transmission in and it slotted straight away. TIP WITH THE TORQUE CONVERTER: As posted in this thread before by Puff, make sure the nose of the torque converter sits inside the bellhousing. I pushed the converter on and it clicked on what I thought was 3 times but it was twice as the nose was still outside. If this happens, continue spinning the transmission clockwise whilst putting some pressure as you push (doesn't have to be excessive). Eventually after 6 or 7 rotations it will just slot in again and move further back and be seated. You'll definitely know when this happens and the nose of the converter will be inside the bell housing
  13. Thanks mate. Yep, perhaps so. The only way to check was to take the transmission oil pump apart as you said. Thanks for those ZF brochures! I found one video that detailed actually taking the oil pump apart. I just wouldn't use a screwdriver to separate the pump gears. Probably better to use a small punch that's long enough. The screwdriver took a little thread off each hole. You don't have to mark your pump gears either. They have dots for markings. Just take a photo and replicate this when you put it back together. Now waiting to see if I can get the 56mm bolt I burred and extracted. Alltranz don't have any. If it is super expensive from ZF, I'll by a stainless steel round end bolt from bunnings and cut it to size. Alltranz charge $43 for the mechatronics connector plug housing (black plastic circle on right side of transmission). Mine was still in good condition so I'll just put it back in. Sonnex sell a kit as well for the transmission bridge seal adaptor and 4 mechatronic cylinder seals. $66.
  14. Okay, well the trans oil pump is off and gears are separated. We're fortunate as falcon owners that this gearbox was put in other cars (particularly BMWs) as there are a lot of videos in tearing them down. Some guys do full rebuilds and its actually interesting to see all the clutch packs involved. Would be fun but yet again, could be an expensive mistake. Luckily the oil pump is first off the rank in disassembly. So I had a look at my gears and tabs. I can't see any scoring, indentations or scratches on the gears or or shaft. The tabs are perfect, not a mark or indentation. They are hard pressed metal so I am surprised people bugger this up. Maybe if it isn't line up and you turn on the car it would rip in. Maybe I had them aligned but my flex plate was stuffed. I don't know. I'll paste a few pictures. These are of the shaft
