AllanG6E
  1. thanks for your comments Ozywalker. Where would I look if I wanted to look at buying shockworks?
  2. I'm certainly no expert. But I put mine up the hoist and had my mechanic friend check both wheels spin the same way when you manually turn it. I've been told apart from a nice skid, this is the best way to check. Is there a number or anything I can check for?
  3. I have a G6E Turbo 2013. My car has an LSD. Is it possibly the earlier ones that dont have the LSD? Simple fix, just buy a later model. The TruTrac or XR6 turbo diff, will likely cost you more then simply buying a later model
  4. I have just bought a Ford Falcon G6E Turbo 2013 and its stock with 72km on the clock. I would like better handling & I would like to keep a nice ride if possible. (I understand the ride won't be as smooth as stock) I have looked at the following options.... K-Sport coilover kit - $1299 (ebay) XYZ Coilover kit - $1380 Pedders XA coilovers - $1500 This does not include fitting. I've been quoted $350 for fitting Has anyone had any of the above & can share feedback? Which way should I go?
