rcklssrabbit
  1. Hahaha honestly after all that, the last thing I wanna do is jack it back up and put stockies on it, tomorrow is a new day though... Lol
  2. So exhaust is in, wastegate fixed and the difference is unreal, it's a bit loose in the dry even on 20"s lol. A little bit smokey but that's probably because the tune needs a slight touch up but other than that it's going the way it should be!
  3. Pretty sure 0.7 is what I gapped them at , can't remember but will double check. Turbo is already ported I believe and I will be getting on the dyno soon, once all the issues are fixed. It was running rough for a while and previous owner has replaced coils so it's had a miss at some point, probably for a while. I'm thinking the reason is more that it's a factory cat with 200xxx kms with 2+ times the boost from factory lol
  4. Mate I think you're on the money. Did coil packs and o2 sensor today, made no difference. Was thinking cat so temp tested it (factory cat still) was red hot and twin pipes coming out of it were cold. Found an xforce system for sale from the turbo back dump pipe and all with 4" hi flo cat to 2.5" twin setup so snatched it up. Stripped exhaust back ready to bolt on and found wastegate wasn't shut, was loose as anything could almost fit my finger under it that's how bad it was, so pulled the manifold and turbo off, adjusted it so it's shut nice and tight now, cleaned everything up fixed an oil return leak while I was at it. Will post results tomorrow, it's not going to know itself, should get up and go now. Also what would you recommend gapping the plugs too on 15psi?
  5. [emoji23] When it's running right [emoji108] I would except it's a good 3 hours away in Sydney somewhere and no idea where it was done. Throwing an O2 sensor code too, so gonna replace that tomorrow and borrow some coilpacks of a mates car, but I feel like its a bigger issue than that. Don't understand why it's so gutless
  6. So I've tried just about everything and scoured the forums but can't find a resolution to the problem I'm having. Car is an 04 XR6 turbo Ba 4 speed auto. Upgraded Intercooler and piping, throttle body relocation, GFB boost Controller, turbosmart actuator, shift kit, Tuned to 15psi but have set boost to 11 through controller, doesn't make a difference either way. Has new plugs, intake manifold gasket, all leaks checked, throttle body replaced as it was throwing codes. Tried standard boost solenoid too and cleaned it, bypassed straight from turbo to actuator- same problem. Nothing I do seems to change it. New fuel filter, changed plug gaps nothing makes a difference. Car feels sluggish to get moving but comes on boost okay and will hold whatever boost it's set at in a straight line, but if I get right up it and it loses traction (rarely ever and only ever up a hill) it dies in the ass, usually pops and has a breakdown for 30 seconds or so. What is causing it and why is it such a slug. Shouldn't be such an effort to break traction on 11-14psi, even on stockies. Won't even stall up on the spot, barely even in the wet sometimes. Traction is permanently turned off through the tune and fry's up fine cutting hoops so don't imagine that's the issue. WTF is wrong with it, starting to drive me insane.
