Gun40t
9 Neutral
  1. Do you know what size the studs and nuts are by any chance? I live my life a red bull at a time those 8 hours of sleep I'm free
  2. Hey guys So recently did a spanner check on the car hoping that everything was firm and tight, unfortunatly I found there is 2 studs and nuts missiing off my turbo flange. I have been looking into the stage 8 kit which they pretty much gaurentee they will never come off, could anyone tell me the size of stud and nut size needed for the Ba xr6 turbo t Thanks in advance. I live my life a red bull at a time those 8 hours of sleep I'm free
  3. Does auto technic still do kits? I live my life a red bull at a time those 8 hours of sleep I'm free
  4. Following. I live my life a red bull at a time those 8 hours of sleep I'm free
  5. Hey guys so for ages I have been tryna find what is wrong with my car I have scanned it no codes, but I've lost power down low abit it idles like sh*t to the point it nearly stalls, I have looked for leaks and cant find anything I probably need to go get a smoke test, the idle gets worse when air con is turned on, I can hear hissing in the engine bay, under the impression it's the aircon lines, I'm ready just to go and buy a gasket tomorow and fit it up I have also been told my a mechanic that there was oil coming out of the intake manifold which I found odd. But I had a faulty pcv at one stage which I replaced, could be crank case pressure not sure, if anyone has any ideas. If not and you think the same issue please give me some info on changing it. I have more tools then a snap on truck so I will be able to do the job thanks guys. I live my life a red bull at a time those 8 hours of sleep I'm free
  6. Blocked off bov sounds like its guna stall and u lose boost with the turbo..
  7. So tonight I brought the factory blow off valve to replace the stupid blocked off sh*t the previous owner had done I was hoping u could shed some light on where to find the vacuum line that goes into the top of the bov.
  8. Probably be a good idea to smoke test it hey?
  9. Also have a question keith I seem to have a high pitched squeal coming on boost at around 4000rpm, sounds boost related ive had to cable tie my bottom intercooler hose because its been a *beep* and dropped below my bar can something like that affect boost noise if its pinched in about 8cm. Cheers brother.
  10. Thank you very much for your help keith I will source some nuts today from the local nuts and bolt shop, hoping this eliminates my annoying sound maybe will help with less of a boost leak. Would you recomend these as the stud kit for the dump pipe to turbo?
  11. Yeah I have unis and stuff and I can get the top 2 but do I need to do.from bottom.of car? Sorry misreqd that thanks man ill give it a crack tonight I brough some m8x1.25 nuts I was told that's what I needed
  12. Anychance of the tools I need to do it or I have multiple tools but I want to know how to tighten all 4
  13. Is it possible to put the turbo bolts on or to I have to remove the entire thing.....again...
  14. Hey guys ive got a horrible sound its a like skreik sound from my turbo on boost it make its bost target but sounds horribly I have got one loss manifold bolt, the turbo is missing 2 nuts which im.waiting to replace could this be the issue whats a good way to test for a boost leak cheers.
  15. They look like mamba cheap studs, ive just ordered a whole set of locking nuts and bolt kit from gcg today. Theyre always loose lol do u have a pic of the factory setup how its supposed to look like.
