As far as I know It's got a X force cat back with what looks to be a 4 inch down pipe and cat, Bigger intercooler (Unsure of brand), Different intercooler piping, cold air intake, Uprated valve springs and Turbosmart Dual port blow off valve. As for anything else I'm not sure. I removed each coil individually while it was idling and all of them affected the engine. I bought another coil in case and tried swapping it out with others and that did nothing.
As for boost amount if I read the boost gauge it's got which is rather hard to read it gets up to about 10 psi at most which doesn't seem to come in until around 3k rpm otherwise it's usually sitting at 5 could of been tuned that way I don't know I'm not completely familiar with turbo cars even though I did own a xr5 turbo beforehand.
I didn't look into it properly to see if the head had been taken off but maybe it has maybe it hasn't I'm gonna be doing a compression test in the morning.
When I pulled the new plugs out all of them except for 1 and 4 looked fine. 1 looked black like it was dry compared to the other and 4 looked like it was wet and not firing but the coil works so that led me to believe that it's probably leaking coolant into cylinder 4.
I had the battery disconnected for a few hours before it started this so I'm hoping that it didn't effect the tune not that it should of.
