AzSilverBullet
  1. I need atleast 98.73 haha Why do say the ZF will need 25mm? Also I wonder why Hardy Spicer only make replacement uni joint up to BF, No FG!?
  2. ZF auto. We know that uni shaft is 30mm ID and CV shaft is 35mm ID. My best guess is that depends if u have a manual or auto as to needing 11mm or 25mm offset center height. Think I best just pull it out first and go from there....
  3. Tailshaft Center Bearing. I now know I need 30mm ID coz its a uni joint shaft but not sure if need 11mm or 25mm offset center height. Go on Hardy Spicer website - Center Bearings - Ford and you will see there is 4 options for FG
  4. Ok so what about offset bearing height? Maybe it depends on auto or manual for 11mm or 25mm?
  5. It looks like it would be hard to get a accurate measurement of inside diameter while the bearing is on car. How did you do it?
  6. So there is 4 different ones for FG. I am hoping I can find out which one I need before I pull mine out. My car is a 2008 FG XR6 turbo sedan auto. Does anybody know if my particular model runs a certain one or could it be any of the 4? There is - 30mm inside diameter with 11mm or 25mm offset or 35mm inside diameter with 11mm or 25mm offset.
