adams355
    4
Everything posted by adams355
  1. Not holding boost, hits 14 or spikes to 16 psi then dies off straight away to 8 or lower.
  2. ok, let me clear that up my tuner isn't the exhaust or actuator guy. I bought the car with a 14psi tune in it done by a sydney tuner. When I called that tuner he told me it had been tuned to a manual boost controller hmmm. This is well known tuner. Anyway, actuator is dying as well but it has 1000cc injectors, cooler, pump and some other stuff I did so see what happens.
  3. Nah this ones been mentioned plenty of times here. I use to work in the industry- lpg so it gives me some kind of reference and a lot of catch up knowledge here has been great from all.
  4. Thanks puff you are a champ. Yea I was a little suss on this guy he is well respected up here though. Didn't know the difference with BF cat ect. Funny thing was it wasn't in his catalog either. It showed the BA twin cat under BF. So yea, got a $200 quote on the phone and $550 when I dropped in. I thought it was bad when I said I had a V8 now its insane at the mention of turbo. So that's $700 for an actuator install lol, $550 for basically a cat and some pipe in the same week. Don't think so, going somewhere else. I got the tuner down $500 off quote as well. It must of sucked in the heyday with these things. Thanks again.
  5. Puff or someone, what is exact size bf twin exhaust (ID and OD). I was told by an 'expert' today its 2.375 (60mm)? I actually hope it is if its bigger. Thanks.
  6. Any new tyres are good
  7. ok sorry I meant edge synthetic when I mentioned Castrol, the magnetec would work but you said best sorry
  8. Penrite has this 'extra ten' approach no one really knows why its pretty old advice considering they are using synthetic oil now. The most important number is 40 that's what ford recommends.
  9. Don't use HPR10 as recommended by penrite. I f you want to use penrite use HPR5. 5W-40 full syn from any of the major players is the best, Castrol, Valvoline, Shell, Mobil One. If we were in the US we would run 5W-30 on the newer cars but that's another story. Look into viscosity index and TBN
  10. Ok that's good to hear, just hope its nulon and not nylon though...
  11. Ha nearly forgot, got quoted 7 hours for an actuator install at a well known gold coast tuner on Friday.
  12. Easy with a hoist. Not much fun otherwise...
  13. My rake is perfect on the super lows kings but its for BF. FG is a bit different I would guess.
  14. Just go superlow Kings, don't use standard shocks unless you want them in your engine bay or your strut towers bent. I have superlow with monroe GT its decent. Would go Bilstein if I had the choice, check out koni and KYB as well, from memory KYB was a bit softer, different car though. Make sure you get short bump stops front and rear and a 27mm front swaybar. Standard rear bar is fine for lowered springs Coilovers pain to set up and every change needs an alignment $$$ unless your into that...
  15. Sack Reynold's urine testing man... http://thorzt.com/v8-supercar-drivers-deal-with-extreme-heat/#.W7oKbylkI0Q
  16. Has anyone ever seen a claustrophobic turtle?
  17. Yea, yea I will just use the Mann. K&N wasn't that great and I don't trust the Aeroflow on it now.
  18. Do the larger oil filters with 3/4-16 UNF 2B thread fit from BF on? Like the larger K&N one, won't be using that though. Does it have to be 2B
  19. ^ Steamy prison fish... hmmm
  20. Yea sorry used one bracket large right angle, just went to take a pic but phone playing up. What is the fan running off? Yea mine is a bit smaller than that only just gets to 80 degrees in heavy traffic otherwise sits 55-70. My fan comes on at 75. Will be interesting to see if you need the fan with the bigger cooler
  21. Goats taste nice... Put it in front of the drivers side wheel if u haven't got CAI there. Mine just screwed in fine didn't need brackets.
  22. I could only look once then it started freaking me out.
  23. Yep this. I'm being a pain tonight but this is the beauty of this motor. Go e85 tune for insurance or just buy another one. Unless its at the drags, skid comps or circuit everyday.
  24. Ok nulon - https://www.ebay.com.au/p/Nulon-Low-Viscosity-Synthetic-Automatic-Transmission-Fluid-20l-Lvsynatf-20/17022271471?iid=153129674381&chn=ps Wouldn't want to be guinea pig plus its dearer
