adams355
    4
Everything posted by adams355
  1. What diff and suspension? IRS? We were running tens in the 90's with 1200kg commodores. No turbo.
  2. Thought I put this here my experience Nulon 10w-40 Full syn and K&N oil filter. Car was daily driven with a few long trips it used at least 500ml, had noticeable blow by. Oil felt tacky and had red tinge at 6500km oil change. Vavoline Synpower 5w-40 and Aeroflow oil filter. Car was daily driven, a few long trips, 2 dyno tunes. Oil was still 'oily' used zero oil, no blow by, dyno tuner even commented it didnt blow any smoke at all. Had minor red tinge to oil after 7000km change. Valvoline Synpower 5w-40 with Motorcraft FL-280S should be good, give me 6 months. 2c
  3. Yes as above plus they have to be Chinese street tyres now
  4. The zf will slip in third or fourth gear until it heats up to 30c fluid temp, it was designed to do that. I warm mine up for a few minutes it has air/oil cooler and it sometimes slips a bit to I get to the end of the street but stops exactly on 30c on the torque app. It does warm up idling. I think the greatest benefit of the air/oil cooler is that the trans fluid can be kept under 80c instead of hitting nearly 100c with the crappy milkshaking stock cooler. Mine was definitely suffering with the hot trans fluid temp before I changed it.
  5. Have you still got the stock cooler on it?
  6. No worries check out hoontune and blacktrack performance for your tune from what I've heard. See which one is the least of a money hungry arsehole
  7. Really in Newcastle, its a hole I was born there. You are lucky I remember go here there is one at Beresfield http://www.driveline.com.au They weren't a rip either. Goodnight Bigdog
  8. The court said I'm only allowed prescription drugs now. #freetheweed
  9. I was already coming down so don't worry about that
  10. Really keen for this or a 2000 hp build...
  11. Chinese tyres are the best
  12. Ok sounds good, don't go anywhere except profile in Brisbane. Unless you want to go to Toowoomba lol.
  13. I wouldn't do the exhaust honestly just do the cat or venom pipe. The car starts to feel modified with the bigger exhaust and noise. The standard system is quite capable. Anyways where are you up to on it?
  14. Engine flush x 2. Penrite flush is the best use cheap oil with 2nd flush and flush additive.
  15. Yep you have that right that's where I ended up. Had big dramas in Brisbane. I would only use profile in Brisbane at this time. But won't be going anywhere except forced from now on.
  16. Used the 255 it does the job. Quieter than the walbro 255. That's the in tank ones anyway. Have race works injectors as well both have been given a hard time, seem fine.
  17. Good old classic plug that one. I found the iridium ones best for fuel economy but nothing else, might last a bit longer. Yea the ford LPG ones still seem like the go. $50 a set about. Not much more than the NGK. They come gapped at 0.7 which is a bonus.
  18. What plugs? The gap will increase as they age.
  19. It would be for sure. Great company yella terra. Big in the v8 world, great roller rockers too lol. Yea it is, http://www.vpw.com.au/Category/Index/514925?Brand=Yella Terra
  20. I have a pcmtec tune and the quality is far better than the sct tune it had. You have to find the right tuner though. The car feels very refined and feels like it just rolled off the factory floor. I have a fuel issue over 4000rpm so im rev limited to there but once that is sorted it will be pretty much exactly what I imagined the car could be. 400rwhp @ 4000rpm with just the common mods.
  21. Yea that's what I thought when I was checking with a light touch it would kink in and out. Fingers crossed. Dont know what else it could be. Much smarter people than me are stumped as well.
  22. Yep that's it
  23. But I love kinky hoes... its not intank keithy
  24. Yea ford dont make them anymore. Its the outlet fitting from the module to fuel line. The part numbers are BA9E964A and BA9E965A. $55 from the wreckers. Send and return. Found mine would kink easily hope its the issue, it was leaning out quicker with the 340 pumps as well. Sort of makes sense.
