Jacobcurtis
2 Neutral
751 profile views
  1. Thanks for yur reply mate, I put a k&n panel filter in there bout 3 months ago so it’s pretty clean, could do with a clean but it’s not bad.. UPADATE: I forgot to add my car is running really rich, Constantly pumping crap ton of black smoke out the exhaust..
  2. Hey guys how are we? I really need some help with an issue that has arisin with my 05 ba xr6t. ok so problems- Car missis on idle. When either cruising ( no matter what gear) or even holding the rev at the one point my car seems to miss fire until I push the clutch in and roll until revs drop and it kicks back in. Does not happen under heavy load. This problem only occurs ranging from the 2000rpm-2500rpm. No other rev, for some reason it is very specific hah... Now why I think it might be over fueling is because when I plug my code reader in and get it to mis it says the fuel system has an error then when it stops missing it says all clear. The cam control gaskets on the rocker cover had been leaking and sending oil into the 1st and 2nd spark plug barrel soaking the coil and plug in oil. I assumed that might have somthing to do with the misfire. Fixed that but only helped for a couple of days then issue came back. Shall Le I just bite the bullet and take it to the tuner and get him to have a look at it or does anyone happen to have and ideas without spending big money. Look forward to hearing from Yu guys! Thanks heaps fellas
  3. Thanks for yur reply! Yes I know that replacing the piping won’t help the blow by, but when the catch can is installed I don’t want to have rubber pipes with oil embedded into them on there, cause it will just send oil threw everything again. Ok thank Yu, just after advise from people and what they know. And when installing catch can Yu plum from the rocker cover breather ( near throttle body ) to the can, then plum back to the pipes after the air filter correct?
  4. Hi guys how are we? Hey I am stuck and need help, I am looking at getting process west stage 2.2 which comes with under battery air intake, throttle body relocation and intercooler of course. I’m confused with The boost sensor that is located under the battery, how does it connect up to the new setup? As the under battery intake replaces the intercooler pipe where it is attached to from factory. I am doing this cause I have recently had ALOT of blow by all threw my pipes and intercooler so I’m replacing the lot and getting a catch can to hopfully stop the blow by. Any help would be great! Thanks guys
  5. Ok awsome well I’ll Have a look around for the right person to do the job! What fuel pump would be a good drop in replacement box stock T? That is another thing on the list but don’t know which way to go. After I do all this I want to run at least 500rwhp would be nice, just need a new CSC for the clutch though.
  6. Thanks k31th for the advise, would still be stuck if it wasn’t for this forum! ok I was looking at the atomic heavy duty springs I think they are 80lb for only $360 and Yu can use standard retainers or the atomic ones. I was trying to post photos but can’t figure out how to do it hahah
  7. Update, super cheap sold me the wrong part number spark plug, went back to sort it out, and they gave me the correct ones with a .8mm gap size, which went cheap haha, put them in this arvo and it solved the missing problem! Car goes like a dream. I still want to put genuine coils on it soon, get rid of the cheap ones and yes I am keen on uprgading the spings but I’m unsure of which ones to go with though, like will I need to buy retainers as well? just bought a process west stage 2.2 intercooler kit which comes with thottle body relocation and under battery intake so next thing is springs then tune
  8. Ok awsome so then I’ll do the coils and get those plugs then I’ll report back. Cheers for yur help!
  9. Ok thanks mate I’ll have a look, I just did a bit of research and the lpg spark plugs are 0.8 gap and they are the iridium ones, they should work yea? Shouldn’t be any difference between lpg spark plug to standard ones hey?
  10. I just had a look at my plugs on ngk site, they have 1.1mm gap, so what do I do there?
  11. Cheers for that ok I did not know that, could be worth looking at the gap cause it got worse as I put new plugs in, checked them yesterday and being 1 week old their black as! I want to replace the coils and put genuine in anyways.
  12. Yea I was planning on doing coils very soon, I can drive it light throttle and it’s doesnt mis, as soon as I plant it, it behaves like a pig, it keeps trying to boost but just keeps mis firing, only high rpm though... live in qld and the fella that owned it before me, got it tuned at torque n tune on the Sunshine Coast. They are a good mob the do a lot of xr6t’s around the coast there. And plug gap should be fine as the plugs that went into them are for the xr6t and the gap would be measured at the factory.
  13. Hey guys sorry for late reply been working on the car. Ok it’s an 05 ba xr6t 6 speed manual. - coils replaced about 2000kms a go, not with genuine coils just cheap ones as I needed a quick fix at the time. -plugs a week ago with Ngk iridiums -standard internals/ valve springs, cams -been tuned to 10psi on 98 making only 360rwhp and 800nm torque -growler intake box -60lb injectors -high flow cat with twin 2.5 system -replaced turbo with a direct replacement with same actuator setting, built by grant at pro boost in Sydney. -I recently replaced intake mani gasket, exhaust mani gasket and whole rocker cover gasket kit. All rubbers and hose clams have been replaced. 1st gear doesn’t mis fire or anything, 2nd gear around 4500-5000rpm it starts to mis but doesn’t blow smoke and 3rd and 4th get to about 3500-4000rpm and it misses like crazy usually blowing out a lot of black smoke (un burnt fuel) Every time I come to a stop at the lights or intersection the idle either drops to about 300rpm or it just stalls. Doesn’t stall often though usually just keeps running, but it shutters when it does this. Coils that were used before I replaced them were Voss coils I think and I just bought cheap one from matcher auto parts on eBay.
  14. Hey guys, my car misses just like this, only under boost and just blow a crap tone of black smoke out the back like the waste gate is just dumping all the built pressure when it spoils, done coils and plugs, going to do fuel filter, replaced turbo with direct replacement. How do I shorten the spark plug gap?
  15. Ok thanks, I will give it a go and see how it goes.
