ItsWarps
1 Neutral
  1. ItsWarps
    Help!?
    Figured it out guys, cheers for your help
  2. ItsWarps
    Help!?
    Yeah I had a feeling that was happening from the start. Oh well im just gonna pull it all out when I knock off and re-run the wires I connected lastnight to see if that helps. Other wise I'm just gonna have to run all new speaker wires which I should of done from the start haha
  3. ItsWarps
    Help!?
    @Ralph Wiggum pioneer mvh-285bt, At first I piggy backed of the existing speaker wires but found I can't have both the icc and head unit on the same wire haha.Sso I cut the end going to the icc so now all speaker wires run direct to the new head unit, it was all working sweet as until I stuck the fuse panel and the glove box back in
  4. ItsWarps
    Help!?
    @k31th I just reset all the head unit settings just incase I've somehow muted the head unit but still no luck, which fuse is the HU fuse on the fuse panel? Can anyone supply a pic ? I'm a rookie
  5. ItsWarps
    Help!?
    @Ralph Wiggum yeah true, I'll muck around with the settings on the headunit a bit more whenI knock just incase I have
  6. ItsWarps
    Help!?
    @Ralph Wiggum direct to the hu @k31th yeah gonna get a new fuse for the headunit and see how that goes
  7. ItsWarps
    Help!?
    Alright fellas, spent 4 bloody hours wiring up a new head unit in the falcon lastnight, wired up correctly everything was working perfectly, then once I put all the panels back on the new head unit won't play sound? Still has power and works and the icc works fine but for some reason no sound? Could it be a kink in the wires doing somewhere doing it?
