Limpmister
  1. Hey guys ive had my Ba Xr6t for a while now but not even 12 months ago ive modded everything to get more out of it. Only recently its started going into limp mode, but its not the normal 3rd gear max limp. With this one im speed limited to 40kmh it will not let me shift up or down. D is flashing on dash. Only way to reset is to turn car off wait a bit turn on again. Sometimes it works quickly and sometimes it takes over 20 mins to get back to running normal. Ive put the scanner on it and it has a big list of error codes from thermal fan sensor fail, Ignition coil fail, shift solinoid fault 1 to 4 (explains no shift) and fuel pump fail. Removed the codes and rescaned when not in limp mode and these errors dont come up. Need help to determine what is causing this. I was lead to believe it was engine wiring loom. Done the replacement and its still there. Ecu maybe?
