Rickybobby
  1. I had a mate who used the 12vplug and it cancels out the windows when the headunit is running. Draws to much power for the motor to work. Hate to be a pain but what one is the Bluetooth plug and what wire of it do I use for just mains power? Photo reference would be sweet!!! I originaly had a aux plugged in but it created way to much interference noise. is that the same plug?
  2. Hey guy n gals, running a aftermarket stereo cause my icc isn't workin and I can't deal with silence. where is a good place to tap into to get a ignition power supply to turn the headunit on. I have run a seperate wire for constant and ground wires just not sure if the best place to run a power wire. Cheers
  3. Yeah I have tried the battery trick and all the fuses seem to be fine no blown ones I've been quoted by ford to get it re coded but will that fix the windows and the gauges ? Dose anyone know if the windows run through the icc
  4. Yeah it can all be replaced haha but why spend more than what there worth on fixing it!? When I can't even find what's wrong
  5. Haha that's a understatement I pulled a busted rear turbo fan from the exhaust random aftermarket wire looms under the dash that go no where and problem affter problem. Ive never had this much trouble from a car.
  6. I changed the gasket between turbo and manifold and squeal went away.
  7. God I hope so cause I'm at the point it's has had to many finger in wrong holes by previous owner
  8. Just going to I <3 Bananas it off. To much fingers in wrong places by old owner
  9. Hi all, I have a 2005 ba xr6 mk11(currently wanting to burn it to the ground) my icc unit is not working has a security code on it, and to top that off none of my windows are working from either the main switch or individual door switches. Also the dash cluster is not working either. Jas anyone had this issu and what can I do to fix it beside write my car off
  10. It happens all the time while driving u less there is no boost like accelerate up and then just coast along under 2k
  11. I have a video but I don't know how to post it
  12. Sup guys n gals new to this page just wanting some advice!!! I purchased a xr6turbo ba and when under acceleration it makes a loud squealing noise!! Any help would be much appreciated rickybobby!
