Lthlwpn
Everything posted by Lthlwpn
  1. Lthlwpn
    Bad zf tunes
    What do you need to pull tune car not working Not sure if selecting a gear helps when it has done a shaft that way to buddy
  2. Lthlwpn
    Bad zf tunes
    Are you saying I shouldent be driving a car not sure what you ment there
  3. Lthlwpn
    Bad zf tunes
    Yeah bout 60 70 ks put your foot in to it and and drops down a gear that is kick down . The mustang shaft wich is the 6r80 transmission wich the new rangers have you need pump some different bearings and bush that supports intermediate shaft into the back of the 6r80 input needs to be made and torque converter modified and a few other things im probably missing
  4. Lthlwpn
    Bad zf tunes
    Whats abuse I just wanna go drags now and then and and be able to use the kick down whats your recommendation
  5. Lthlwpn
    Bad zf tunes
    If it was $990 for shaft then its the same as mine
  6. Lthlwpn
    Bad zf tunes
    Not sure dude Lol I've got final drive chromoly tubing and beefyer center bearing tail shaft for it
  7. Lthlwpn
    Bad zf tunes
    Cant wait to see what mine makes this time did heaps since last time
  8. Lthlwpn
    Bad zf tunes
    that's not a bad run how much hp ? Dose it shift hard and how dose the old kick down go hahaa
  9. Lthlwpn
    Bad zf tunes
    Who did yours dude
  10. Lthlwpn
    Bad zf tunes
    Yeah I appreciate the offer from turbotrana its just I live in melbourne now cars in perth I work 2/1 roster and just had a new baby a week ago so no time that's why gonna put car in get it done in perth and send it over
  11. Lthlwpn
    Bad zf tunes
    Lol dude that sux tin can alright I must of got a big batch of tin cans I get mine cryoed $50 a shaft and its 50/50 tune and parts I know its not parts and as im puting a short motor together over a bit of time id rather put billet shaft in and not worry about it later on and exedy clutches are good but dont need them as more oem ones do the same cheers for the info though
  12. Lthlwpn
    Bad zf tunes
    Thanks dude but gonna get monsta torque to build the trans there billet input shaft and trans tune this time round plus get them to do oil pump ,valve springs head studs, 98 and e85 tune
  13. Lthlwpn
    Bad zf tunes
    Cryo shaft All new clutch plates stock amount Mesured up . Cryoed pump assy Zip kit through valve body New seals Torque converter split cleand re assy Bushes all good and bearings I broke it with 400hp the first time Then 528hp the the other 3 times Both tunes done at bpt and yes it bangs into gears no fart inbetween so no torque reduction yes some of those shafts were done on kick down first time was off the line with 400hp was gonna do the 6r80 input shaft conversion but I dont have time and cant find the information
  14. Lthlwpn
    Bad zf tunes
    Yeah I built the boxes last one cryoed shaft but still busted shaft plus I only gave them tune to do really coz I do all mech work my self I dont have time anymore to do it the box that is
  15. Lthlwpn
    Bad zf tunes
    BPT
  16. Lthlwpn
    Bad zf tunes
    Hey in perth anyone had bad zf tune as I have had 4 busted input shafts now
  17. Not sure yet
  18. Auto gonna have bout 450kw or over on e85
  19. Whats the price in perth these days to get billet oil pump supplied and fitted
  20. I was aiming for 450kw so you think the exhaust should be fine then .and yeah the motor is stock just valve springs
  21. Dose anyone know what sort of power you would get with this system 4inch bellmouth dump 5inch cat into twin 2.5inh to rear muffler . The rest of mods are well car is bf f6 it has .Walbro 460 intank .pw twin 460 .pw twin entry fuel rail with both lines To it with t smart reg .1000cc injectors .pw big race intake .plazmaman plenum .plazmaman 1000hp cooler plus hot & cold pipes .xr6turbo developments stage 2 highflow turbo with billet wheel wastgate mod .valve springs Will be tuned on e85
  22. Yeah cheers
  23. Yeah cheers that probably wouldn't work thanks anways im running a high flow turbo with billet wheel and stock exhaust manifold so that one off that 1200hp car would be for high mount
  24. Do you know of anyone who has done it like this at all Cheers
  25. Sedan mate I wanna keep the ba/bf 4inch dump and use the fg 4inch from catback
