ratter
    58
Everything posted by ratter
  1. 2 funerals in 3 weeks is what's pissing me off
  2. $30 per horsepower on the run, could work out dear if you have 100 hp at the rear wheels
  3. and then eventually start to feed on your face, I have a friend who's a copper, she tells me this is a common situation
  4. WPYO? Not being able to get over 300 rwkw on standard BA injectors!
  5. no it stays on
  6. this thread is full of fail
  7. did you take the timing case off? if not you can not check the timing accurately using the timing marks to be 100%, not saying that is or is not your problem but just making you aware
  8. ok just checked my info BA 6 cyl thermostat is listed as opening from 89-93c and fully open 103-106C
  9. depending on customers requirements and mods we may fit a low temp thermostat, too low and fuel economy suffers, oil may not protect as it should etc. Forged pistons, that's another debate but piston to bore clearances are probably the biggest deciding factor in that car
  10. Factory thermostat do not start to open until something like 92 degrees and are not fully open until closer to 100
  11. no not really, just annoying and people will ask what is going on
  12. It shouldn't do it but it is common on some tuned cars but it should not have just started happening if it was tune related
  13. anything can be broken if you try hard enough
  14. a high stall makes the car feel and sound very laggy/Lazy
  15. if blowing up 6 speeds you may need to change your driving style
  16. best depends on what you are trying to achieve
  17. one of them had a 18 psi tune it but was going to something like 23 psi on a cold night with the port job and tune that was in the car
  18. have had to fix 2 NSW port jobs in the last few months, not all port jobs are equal and that's not just directed at NSW port jobs
  19. only after stainless knocked him back
  20. if answer was yes Congrats
  21. can't do typhoon snorkel on the F series, you do the V8 box and snorkel, My test showed a clean factory filter flowed as well as a K&N at 300 rwkw
  22. stock or modded car? do you want it to stay on LPG to redline?
  23. I have a twin pump bracket at work, could be persuaded to sell it off
  24. or hannatech or carmenscan etc etc
  25. Xcal may not even pick up some codes while a good scan tool will
