ratter
    58
Everything posted by ratter
  1. I was thinking it was just the rears as they were also turning on the dyno,
  2. have found that there is a noise from the speakers when the radio is turned on, not sure if it's an issue at the moment though
  3. I think I may need to get off that Lime only diet? Problem is not the fitting kit, problem is your engine is not big enough to use enough fuel at idle and low rpm
  4. For some reason I was thinking of those just at the rear possibly because of he said 2 of the 4???
  5. the supplier does not give discounts based on volume on their products
  6. http://www.fordxr6turbo.com/forum/index.php?app=core&module=attach&section=attach&attach_id=57127 shows the studs and nuts
  7. all the above can be a problem and your car should not even be getting 7 psi
  8. the body has studs and sounds like you are missing the nuts, ford would be the best bet
  9. agree with the wheel alignment Vs jig, but not a toe and go type wheel aligner, it needs to go to a suspension specialist that understands and checks the various measurements
  10. ratter
    Help Me
    safe you say? Brembo calipers with DBA rotors
  11. get a surge tank or keep at least half a tank of fuel in it, assuming the tune and car is good mechanically
  12. I seriously did, and he paid. For over a month he had been calling and sending emails which Bel and Andrew had spent over 5 hours dealing with him, then he posted he was going elsewhere on FB, but then wanted some more advice, I told him I wasn't interested or would be doing anymore quotes or give him anymore advice unless he started to pay for my time, he rang up the next day and asked could he come down from the northern suburbs to talk to me, I told it would cost him, when he came in I charged him an hours labour to talk to him
  13. I charged a guy $99 to talk to 2 weeks ago
  14. which is why I mentioned earlier there may other things that need to replaced
  15. are you trying o take over from wikipellor?
  16. there is no sensor in the door, as the others have said, there are different sensors around the car if a certain deceleration G force is met, then the bags will deploy , no matter what part of the car has hit what
  17. the impact damage to set off the air bag is from the suspension hitting the gutter not from the minor hit from the pole, it had to hit pretty hard to rip out the suspension
  18. wow, I went 1.669 with no boost 7 years ago
  19. the gutter impact is what would have deployed the air bag
  20. pretty sure PWR used to be in Dandenong years ago??
  21. PWR are waiting on someone to lend them a territory so they can make a kit, maybe give them a call and see if they have a date and volunteer yet
