ratter
    58
Everything posted by ratter
  1. not all exhaust are equal http://www.fordxr6turbo.com/forum/topic/57722-performance-exhaust/
  2. 2nd vote for John West
  3. fuel is injected after the throttle body
  4. did you read the words that Plaz have in their add? it could lead somebody to making a very expensive mistake
  5. ask your local rwc guy whether removing a structural part of the radiator support panel is a rwc issue
  6. how about rather than trying to paint the petrol black, which is a stupid idea, why not run it on black petrol? or isn't coca cola black? or Jim Beam and coke cause we know race cars run on alcohol
  7. morosso used to sell "cool cans" for carby'd cars so yes cooler fuel can help
  8. do you know why the pump gets replaced?
  9. Ralph is correct, assuming the gate is not being held closed
  10. many FG's even stock have some cold start/running issues when when stock, bigger injectors will make these problems appear more so but it can be tuned out and is not normally injector scaling, although bad injector scaling can cause issues
  11. not needed adds extra time to tuning process inconsistent control requires maintenance added cost
  12. no soup for you!
  13. Too early to tell
  14. Will try to answer the questions when on my laptop. The compromise tune will be lower than this current tune due to the compromise to get 2 different fuel systems working on 1 tune, you have to remember that the jtg does not have an ecu to adjust
  15. Not if you have a zf
  16. another genuine would be a better choice
  17. of course it is, 280+ rwkw on 95 octane and so far a little more than that on LPG but no spark added yet
  18. quality of those TB is not as good as genuine
  19. xcal2's still work and can be tuned but the internal memory is not big enough to hold a tune file that has ZF data so basically it means they can not work with a zf equipped car, but they have never been shut off, even though they have not been sold at all by the current SCT distributor
  20. as I said earlier, that info is most likely not 100% accurate but does give a reasonable indication to what is going on
  21. cooks those sausages real quick
  22. oh! did you hear about that?
  23. the boys are using it to fuel their Friday bbq lunch
  24. ratter
    Aftermarket Ecu
    well that would make sense then
  25. yes you, you offered
