ratter
    58
Everything posted by ratter
  1. any tuner using SCT will require a new flash box if your car is a ZF car, if manual the flash 2 can be used
  2. have you priced up buying one from Australia and having it posted?
  3. the stock cooler in the FG is struggling to maintain reasonable temps at 280 rwkw
  4. overboost depends mainly on what your target boost level is, if you want to run 12 psi and can get 12 psi with some control over it, it is fine, but aiming for 12 and having 14 at 0 duty cycle is really an overboost situation and will be worse with cold air, but there are many cars running around like this and they just claim that's how it's tuned for
  5. They are unless it's damaged
  6. Very good info
  7. Radiator support panel affects many things that attach to it, if it not fitted 100% correct there may be ongoing issues
  8. Only seen 2 hurt zf's both in small turbo cars
  9. Delete
  10. 350-380 on 98? According to the manufacturer they are supposed to be capable of 600 hp, depending on how you do the Maths that would work about maybe the 340 - 350 mark
  11. It's best you talk to your tuner about what you want and get them to recommend a set up, that way there should be no excuses if it doesn't perform as expected
  12. no boost controller can cover any mechanical mismatch, sometimes there is just not enough hardware to do what is asked
  13. Assuming you have no valve recession
  14. Actual data does not lie
  15. I assume most states would say that the car needs to meet the emission level it did when manufactured, this would cover most ecu changes enough to require an emission test to prove a modified ecu is legit
  16. It's taller but not as thick
  17. Mods should compliment the power level required
  18. I assume alignment would be critical to get correct gaps and headlight alignment etc, accurate mearurements would be vital
  19. With out the end tanks would be a major boost leak
  20. Not good even at 300
  21. You can not tune a car with just the xcal unit
  22. Yes mate, the eboost has some extra features but operates the same as the factory controler
  23. They are not ID's and no the F6 cooler is not good enough
