ratter
    58
Everything posted by ratter
  1. Stoich is the cleanest overall but some gases are lesser with richer or leaner conditions, but stoich is the best balance and is considered to be the cleanest level, many people think that running lean is cleaner but this is not the case and why cars do not have lean cruise anymore
  2. yep, just go and click away, stage 3 is the best deal
  3. doesn't matter what fuel is used, stoich is always the cleanest
  4. so he did, please move along, nothing to see here
  5. WOW $990 just to check the fuel mixtures
  6. Ralphy is correct, there are protocols in place to stop any out of control acceleration like described, any failure to control it will put it in guard mode, that is unless the pedal is actually stuck down or held down like mentioned
  7. All autos have the boost spike, well assuming they don't flare on the change
  8. a tuner using SCT has to start from scratch unless it is the original tuner and he still has the original tune file
  9. Nizpro's demo had the timing altered to suit the lean condition
  10. no worries mate, yes I was referring to what part is going to cop the blame if it doesn't handle as expected, suspension components should work in harmony with each other, having a mismatch may affect the final result, but that final result is different for what each person may want, you are paying for a great product, give that product a go as recommended, if it does not perform for what you want then try adding the bars
  11. do the coil overs by themselves first, get a feel for how the car is and then try them. Make up your mind to whether it suits what you are after, if you do the coil overs and the sway bars at the same time and it's not what you want then who are you going to blame?
  12. that valve was never designed to control boost, it was there for protection in the case of an overboost situation
  13. most springs are progressive rate which mean the coil has a soft part of the coil, this soft part of the springs can lead to the initial body movement and then the inertia keeps the weight moveing, the shockworks coil over have a linear rate spring so none of this initial tip of the body occurs. Many brand of dampers also have an area of movement before any damping occurs (a dead zone), this is also very minimal with the shockworks
  14. the convertor needs to be fitted into the box first and yes it has to line up
  15. fuel pressure should actually increase with boost pressure, not just hold even
  16. ID 1000's do not need the extension cap on FG's, any tuner can supply them
