ratter
    58
Everything posted by ratter
  1. M80 and M86 take different centres, the ute and sedan turbo take the same one
  2. welds are aluminium, so should be able to be anodized I would think, but different grades of aluminium react differently with the same anodizing process and may appear different colors and that's assuming an anodizer could do the core without damaging fins etc
  3. Bjc mentions 98 octane with 10% ethanol
  4. e10 98 octane will give no power advantage over regular 98 and a little more will be used to do the same driving
  5. Nizpro requires cutting on a FG
  6. Weapon x are not a match for stock ones
  7. Correct
  8. the only way the F6 is a good upgrade money wise is if it is given to you, it looks a little better
  9. this is the beauty of my fuel flow module on the dyno, allows us to check what is actually flowing what and what pressures
  10. cough "group buy" cough
  11. my comment about the 044 was based on the question being asked in a thread about E85
  12. why? there is a pressure loss with the factory crossover to start with, if you could get the number you were after, the turbo would have to work a lot harder than if it would with a non restrictive set up, this would generate more intake air temp which reduces spark which lowers power
  13. Bosch now only rate on their 044's to 500 hours on E85
  14. stage 2 still has the same bar cut off
  15. tune will not be accurate if the fuel pressure is not correct
  16. the bar that is cut off is a composite material and is structural, things do not need to be made of metal to be structural, do you realise your windscreen is part of the roof strength?
  17. have seen several cars that the hose has actuallyy broken down inside and started peeling, leaving blocked pressure regs. surge tank pumps etc
  18. decisions decisions decisions, you have a little less than 2 weeks to make up your mind What are your laws where you live re cutting?
  19. what tool was used to check the codes?
  20. not very good at that power level but either is the f6 one, nothing like the pwr one
  21. maybe you should mention whether stock or if not what mods and boost level
  22. injectors, cat, cooler and tune but will blow your budget. you need to know what power you are chasing before anything really can be recommended. we have a group buy for cats at the moment, can save you a few bucks
  23. pretty sure bendoco has posted pics in his build thread of his when we modified it
  24. yes you will
  25. can't do links for some reason at the moment but it is in our sponsor section
