Cheer up mate it's not too bad! You are in good hands with the gas problems and it will get sorted out for you in good time. For anyone interested, worms car was originally stock when he booked in for the conversion, between booking it in and actually getting it done, he went from stock to 335 rwkw which included new injectors. The problem he now has is the gas injectors are flow matched to the petrol injectors, so they don't need a seperate ecu to control their duty cycle. Using the seimens 60 lb'ers and having the injector slopes adjusted correctly for petrol, they are only in the vicinty of 70 % duty cycle to get the correct fuel flow, now this injector duty cycle is what the gas injector also uses, and these injectors at this stage, even with the biggest calibrator drilled out, will not flow enough gas at 70 % duty cycle to support this power level. If worm used 42 lb injectors and if they made power to this level, the duty cycle would be close to the 100 % figure, so then the gas injector would also get 100% duty cycle there is a chance that it would flow enough gas to support this power. ALPGW have ordered the largest gas injector available from Italy and are prepared to try these when they arrive and in the meantime they are looking at possibly drilling the gas injectors out to increase the flow capabilities which again would be finally controlled by the correct size calibrator. If this all fails,there is the possibility of having duel gas injectors which would require a bit more hardware. The next problem may be gas supply to the injectors, they beleive the intank Walbro pump will be adequate, but if not, they can fit a 2nd intank pump to keep up the demand. This technology although new to Australia has been fitted to hundreds of thousands of cars in Europe and America for quite a few years, but the Australian range of cars is being left to ALPGW to develop. They were not planning on doing any modified cars at this point of time, but as worms car has changed, so has their time frame.
