it's called a security bond and yes last I heard the rental was minimal if you purchased a set of springs but had to pay the security bond which would be refunded when returned
we do try to keep people happy but reality is it may not happen due to many reasons whether trying to get internet type numbers from a bad set up, running 95 octane and expecting 98 power etc or sometimes just don't like each others personality, but any feedback from him or anyone who deals with us is appreciated so we can improve what we do
they are not Siemens, they look like they are a Bosch EV6 injector, but Bosch have their number moulded into the side of the injector, there were some copy 968's a while back that had no number moulded on them, but they are a different color
yep, we all live in a perfect world don't we and the heads do need reconditioning from time to time and should be part of a proper rebuild, a patch up is a patch up, no matter who tries to convince us it's a full rebuild
a patch up job is not a complete rebuild, an engine builder may dummy fit the engine 3 or 4 times before final assembly, there is time involved getting things to the correct thousands of an inch
yes, running any length of time with a warning light on can lead to an even emptier bank account, turning it off at the fist flicker may have saved you thousands of dollars
Driving with no oil pressure will normally totally destroy the engine and you will most likely need more than a short as there is a good chance that the head and cams have been destroyed
Fudging numbers may fix one area but have adverse affects in another, maybe ok for a race car or dyno car but not ideal for a street car But there may be an answer coming, I can not and will not say anymore, whether to confirm or deny
Afr will change with intake temp and coolant temp, fuel temp can also be a factor, peak engine torque is closer to around 4700 rpm on most of these motors
7 psi is not stock and the overboost protection may be cutting in, if it's stock, if it's tuned you need to find out what it was tuned to and whether it is the same configuration
abs is normally disabled after a small amount of time on a dyno due to the control module thinking the front sensors are faulty. Was the car datalogged to make that assumption?
