HI PSI
    50
Everything posted by HI PSI
  1. Can Nobody offer an opinion?
  2. I am looking to purchase my own software (Either vcm Suite or Sct Race pro)for tuning my car. I have read all that I could find on both packages and I am still undecided s to which is the best for tuning compared to value for money. As I understand it Sct software has more tables than the Vcm suite. Are these extra tables beneficial to the tuning of the XR6 Turbo's? I have a friend who is very knowledgeable in VCM Suite. He is going to help me get started and has expressed interest in going 50/50 in purchasing Advantage III software.. Can someone tell the the pro's and cons of each. Which is the better software? Brad
  3. I have the coin sitting here... I'm going to get a cheap 4' mild steel one. I just need the time to order it... I am thinking of buying my own tuning software (Sct Race pro).. I have another person that is inerested also. So I may end up going shares in the Advantage III software instead....
  4. Ahh Cool... I thought that they were re-usable....
  5. I am looking to do my first service since fitting the ETM Turbo feed, oil filter kit. Could someone please tell me what I can se to clean the filter please? Cheers Brad
  6. My ported housing cost me ... Abut $89.. . I still have my spre housing here.....
  7. You seem to have a 20hp earlier through the range than me.. Through most of the range.. Yet wet have the same boost levels... My tune 459.1hp was with that miss/surge problem... What dump you have?? 4 inch??? I'm dying to get one and see what difference it makes....
  8. I was enquiring on another forum, looking for the best possible exhust system for my 500+ hp cloevo that going in to my XF GHia.. A member posted a link to a site in the "States" that does oval exhausts.. It looks the gods and would most definately flow well and fix an ground clearance issues.. OVAL EXHAUST PIPE LINK Does anyone know if anyone in Oz supply this ??
  9. I'm getting a nw dump in 2 weeks.. Then a retune... I ca't have you beating me by 2 Hp... Can I?
  10. Good work buddy... RAce timeGood to see you get some good results... Those Rapid kits are an awesoem bit of gear.. Lol @ the plumb back part... I got pulled over the other day..... Bloody cops..
  11. Hey buddy... How did yu go withe the XR mesh?
  12. HI PSI
    Central Qld
    They ppulled me up today. The cops in the dark blue VE wagon. One transport guy with him... Asked me to pop the bonnet and then proceeded to ask: Q- "What is it with your blow off valve" A- What do you mean? Q- It's venting to atmosphere? A- No. It's plumbed back. Q- No it just runs under the battery. A- yes that is where th intake is... Duh !!! Q- Oh !!! Is it really? They then complimented me... "Good work... Have a nice day".... So I Got the hell outta there... Luckily though they didn't book me for venting my rocker cover to the atmosphere with the breather that I have on there...
  13. HI PSI
    Central Qld
    Oh no.... That sucks... They look so good too...
  14. Thank you for your input Matt.. It is greatly appreciated....
  15. Scotty mesaged me last night, telling me bout your run... Congratulations .... Good to see some good figures coming out of the north....
  16. Thank you very much. This is good to know. Someone told me that the FG F6's had argo rods... I check the prices on new ones today..The FG rods were $65 each retail....
  17. Are the FG F6 rods bigger again?
  18. Hi all.... I have been offered a set of FG Conrods on thecheap and I am now considering throwing these into my spare BAII engine. I would dearly love a forged engine, but other commitments have priority. Money is tight.... So I am thinking of freshening the crank and bearings, Koneski Pump gears and retaining the standard pistons.. I am not chasing Monstrous power. I want a reliable 370 rwkw.. What are your thoughts?
  19. In all honesty the Alpine hub is no worth the money. The picture quality is woeful as it is prone to electrical inteference from the car. I went the ASL Logisica path with a Jvc DvD player. This is by far th best option if you want agood picturre quality. My car was the guinea pig for the Asl system at our loca Alpine dealer. They no longer push the V-Hub as they feel that it is inferior (Picture quality)to my method..
  20. I had big surging isues with mine. Irradic idle,surging and stalling. Espcially on downshifting. It kept smashing the backlash on the diff... All this after I installed my PW Surge tank and 044. Turned out to be the fuel regulator was blocked. It had 800 psi fel pressure aganst the reg. New reg ad all is fine. This is just my experience. I am sure that thers will post also. A coil pack would give you miss right through the rev range. SO not thator plugs... Pump, filter or reg in my humble opinion..
  21. I have now found the problem with mine. It was the fuel Regulator. The fine mesh was almost completely blocked. It had a small hole I the mesh. about the size of a pen nib. I'm guessing that this was damaged due the the majority of te fuel flow going through tis area. The gauge used to measure the fuel presure went off the clock at 800 psi.. No wonder I was having problems. No back for a new tune as it is now running rich... Thank you very much to all that gave their time and advice.
  22. I put the Xcal3on the car today and couldnot bring up any error codes.. So now I am thinking that it may well be the fuel Reg as the problem stared when I put the PW Surge tank and 044 on. The car seems to have a constant miss like it it trying to retard itself. Plugs and coils have been replaced... So not that. Car goes into a shop tomorrow. See if they can work it out..
  23. Humphreys Auto Refinishing.. The best paint shop in town.....
  24. My My problems are a little different. I have a very irregular idle. Sounds like it s running on 5 cylinders. I have replaced the coils andplugs. So they are eliminated. So now to the T.P>S. I a sure that it is the proble. I also sometimes get high idle. But it shows no particular patter. I wentto Ford today to get a prie oon a T.p.s and ound that they only sell the complete thottle body. SO that is out the window... Now to look for an afermarket version...
  25. I used double insulated power wire . Use the pink wire off the fuel pump relay in the engine bay. It is a timed relay and shuts the fuel pump down after around 3-4 seconds of priming.This feature comes in handy when loading tunes into the car. As the fuel pump would run continuously otherwise. If you take the metal screw tab off the relay (If fitted) You can fit the relay onto a tab inside the fuse/relay box and make it look factory.. I ran the wire forwards and then throught he inner gueard. Between the plastic guard and the chassis. It come back through the inner gueard near the brake booster then across the back of the engine with the brake lines... I personally have only one problem with this setup. My fuel pump seems to shut down if I start the car and let it idle. If don't start driving immediately and will do this 2-3 times then it is fine.. If I drive off immediately it is fine... Go figure.. Maybe I need a one way check vale put between the pump and the fuel rail... I hope that this helps
