Everything posted by RAP1D
Seriously have to laugh at this thread, lets break it down in to groups. We have serious performance orientated guys , guys that just listen to tuner X and hand over the Visa, guys that are on tight budgets and have to save... And to top it the thread is also comparing 2 seriously different style cores, bar and plate will always cool better than tune and fin,with respect to actual core size tuners experienced in turbo tuning should know this as its fairly common knowledge. Now Im not having a go at any tune shops or independent tuners, there's ALOT of awesome tuners out there, but unfortunately some are not. People need to make educated decisions, forums like this are a great way to obtain information, but are also a place of great bias and confusion. Some good comments from guys that have used X brand cooler with good results, results that at the time of purchase they were extremely happy with, only to see another car later on make 5-10% more dyno read kws, with a different brand intercooler... did they make a poor decision the first time, or have their expectations now changed because they've now seen a higher power result? At the end of the day, for most of us its how the car drives on the road that is the most important, if you like to go out of cruises and run your mates, then on-road performance is what you need to look at, and tube/fin cooler perform totally different to bar and plate cooler. Refresh time... I am yet to see anyone comment on this, tube and fin will always refresh much faster, making your on road inlet temps lower. So what does this mean? Example, your cruising along at 60kays, your mates next to you, tube n fin being a faster temp transfer, will generally mean your motor has lower temps as air is flowing through the core, the bar n plate, generally considered a greater heat sink, thus holding more heat in its heavy dense alloy core.... nail it and you'll probably jump in front, with inlet temps naturally rising on both cores, the tube and fin will heat faster, but then cool its heat soaked temp much faster... so the next run you do your inlet temps have dropped back down fast, where as the bar n plate is still hotter, so now its inlet temps are a bit higher... so you can see how on road performance will greatly vary between the two cores... but if numbers are still your main deciding factor, data log your car, you'll be able to see exactly what temps are coming in and how your tuner has set up temp v IAT correction... Ill talk about this next as E85 and 98 make a huge difference here. We are lucky to have a lot of temp correction tables in the tuning software (SCT, HP , Sniper), the main one that we look at , in regards to intercoolers is Inlet Air temp Vs Spark timing, as mick mentioned early. What is it? basically it is a correction table that is already set up by Ford, to suit the OEM intercooler and 98oct fuel. We have the ability to adjust this, there is no right and wrong for this table, purely governed but the amount of engine knock (ping). Now on a 2010 F6, this table , at 37.8deg C will not add or remove any spark timing.... therefor IF your chosen intercooler hit a max of 37.8deg the computer will not remove and spark from any timing maps, therefor not reduce power from spark. IF the inlet temps go above 37.8 the computer will start to reduce spark, according to how this table is set, thus reducing power. the next temp indicated is 67deg C, with a reduction of around 3deg spark (there is also a multiplying table working at load / rpm that will vary the total spark, but generally 3deg) so IF you were to manually remove 3deg of spark from the motor at WOT, you will loose a fair amount of power... and that is the most common reason power figures vary between core types (of the same size) How do we counter act this? Some don't, they either don't have the confidence to adjust this table, or purely do not know or have not been taught to do so. Its up to the tuner to adjust this table IF they want to, and if they do, they need to carefully monitor knock, and there are a lot more factors that contribute to knock than just inlet temps. Ok so now you have E85 in the tank, inlet temps are now much much less a contributor to knock than 98... Example, My GT runs 11psi at WOT on 78deg C at 7200rpm on E85, with 27deg of spark timing... do not compare this to a XR6T motor as the coyote takes a lot more spark. If this was on 98 it would ping its tits off and break. To back this up I have also run my G6ET at 25psi boost on E85 with NO intercooler at all, none, No pinging , 18deg spark at WOT and inlet temps of 60-70. Funny thing is back in the 90s when I began tuning and working with turbo cars, a lot of us didn't even have intercoolers, so we had to deal with 90+deg inlet temps, to counteract this we ran water/meth mix's to drop combustion chamber temps, this is exactly what E85 does, the inlet air temp may be high, but the resulting combustion temp is greatly lower, thus working against detonation, on 98 you have huge combustion temps, so lower inlet temps will always be ideal over higher temps. End of the day all the coolers on our market perform very well, there all different sized , different prices ect so yes results will always vary, and all tuners tune differently so again results will vary. But one thing I will say is if your running E85, choose your intercooler on airflow, do not worry about variations in inlet temps... so I guess that's pretty much everyone looking at 450kw plus... dropping 5 or 10deg inlet temp on E85 isn't worth even thinking about when tuned with the above compensations taken care of. Im a huge fan of Plazmaman , and ultimately inspired by the work of ProcessWest, and its great to see comparisons like this but people really need to know what goes on in the tuning side of things, and how the final result of a modded XR6 F6 can vary, regardless of who made what and says what.
- 310 replies
- 18
Tuning is waaaaaay more important... if your tuner is telling you 40deg AIT is too high he aint tuning it right.... if he's telling you that while tuning on E85 run the hell away
Looks like 'boink is right, at 5000rpm is making 370odd kws, changing gear at 5000 would net a 123mph pass or there a bouts... so great tune, great result
Jerry cans FTW
LOL just having a poke at you mate... it was a pretty dim question though you have to admit, how else can u set up injectors. It idles on lambda 1.00 - 1.01 when at over 87deg C, I dont change spark at 600rpm, though It logs at 18deg with minor +/- variation in regards to aircon , pwr steering , and how I have altered the throttle...its all relative...80s idle smoooooth as. 80s are voltage sensitive, and all cars Ive seen seem to exibit various voltages at idle, so time spent in voltage table may be your firend, no need to run them rich.
No Ralph we geuesed the AFRs... simply wet a finger and hang out the boot with it over the tail pipe
Well done matty/joe...550kw is definatly pushing the envelope for a 35 turbo, posibly world wide?
I was told awhile back that Caltex were, or have made a deal with Expensive Daewoo to roll out Eflex in most of their servos up and down the eastern states, so you could drive from SA to Nth Qld on Eflex. I really hope people start using it more and more, otherwise if it doesn't sell Caltex will pull it... Rydalmere Caltex had Eflex for about a year, recently they got rid of Eflex, which is a bummer but shows they will pull it if its not selling.
yeah ok thanks, was more interested in the topic at hand, software v software...
No one picked up on it yet... "fact I also put in PW fuel regulator and W460 2.4L surge tank help explain anything" Its prob got the rail pressure raised... not hard to add 10-20% flow to an injector with increased rail pressure
who breaks axels on a stock one legger? Looks tidy.
that's a pretty large generalisation there Mick, care to elaborate ?
I think we'll see more and more people tuning with Hp, Ive been getting great results with it and so have many DIY users I now know. These days with money being tighter and tighter, if you can save 800 from not having to buy a storage unit, that's 800 on other parts. People need to understand that all these software programs access the same pcm settings, some more some less but all are capable of making the same power, its the tuners input that makes the biggest influence.
torque app looks awesome on a tablet, but even on a phone its great for live and quick logging on the fly, I prefer it over livelink for the ease and speed to set up.
P1227 Dtc (Wastegate Closed/boost Over Pressure) :( :( :(
RAP1D replied to gmhkla's topic in General Tech
Was the original car in the thread , flashed with HP over the previous SCT tune? or the factory tune flashed in, then a HP tune made from the factory and loaded in? Ive had a few issues where cars have been doing odd codes and missbehaving, tryint to fix the sct tune with HP doesnt work, but flashing the stock tune back in and working from scratch ellininates the problems. As mentioned above, SCT reads more tables than HP, but HP has no problem tuning the cars unless there is already an issue with the sct tune... wipe and start again. -
Nice, better than my velcro'd to the dash Ipad lol
I velcro mine to the dash in between icc and dash cluster lol Velcro sounds dodgy as but it holds on tight and its very easy to remove... but for taking video footage I use a phone cradle. Best of all you dont look like an idiot camry driver with a cheapo gps mounted in the middle of the windscreen
E85 Price, Location And Ethanol Content
RAP1D replied to XYZ's topic in Fuel System & Induction Workshop
yep Also there is a ethonal % meter designed to be permanently installed in the car to constantly give live ethonal read outs, a sensor in the rail and guage in the dash, perfect... I havn looked into it but someone here may know, bcl was telling me about it but I cant remember the name. -
I never said it would -
Nice boost control, looks good.
Really depends on how dirty the fuel system was befor using ethonal. My GT has run it since 5000 kays , only ever Caltex Eflex, its done 22000 kays now on 100% stock fuel system, never a hicup and most likely never will until I change some part of the fuel system to a non oem spec part, as in fuel line, injector (o rings) pump ect ect, that is when issues can and may occure. Your a total misguided fool if you think you can put Ethonal into a car that has run for a few years on 98, and not expect any issues weeks / months down the track. If you get a tune done on Ewhatever, change fuel filters within the first few weeks, examine the fuel that comes out, if anything looks sus there may be contaminants in the fuel. The may be minor and just catch in the main filter and that's all, or they may spread everywhere and cause block ups everywhere... Poeple need to understand this. For reliablitiy sake I prefer Eflex, as from what Ive seen, around syd they are mostly new servos getting Eflex, so perhaps they cant use their older existing tanks on Ethonal? But everyones fav United is way way old servo... My G6ET blends in with the silver service G6s totally. On the topic of using different pump blends and effecting AFRs, there are a few ways to get around this, setting of stoich is your friend... get it spot on and its Eflex going to work, United going home, no tilt trucks required. -
Xforce FG exhausts work very well, the 4inch stainless I had on my G6ET (stock exhaust now) was awesome, sounded bad but not silly loud. As for the mild steel version, if anyones heard Vevapowers car on E95 they'll know... gtr on roids!
Has the car been tuned? Those areas can be altered to bring boost on at earlier tps, that's a nice thing to do a conservative low boost tune, itll make it feel pretty quick
I didn't have the software to tune Ba onwards back then
