instro
About instro
  • Birthday 03/07/1974
Contact Methods
  • Website URL
    http://
  • ICQ
    0
    South Coast NSW
  1. Happy Birthday instro!
  2. Happy Birthday instro!
  3. Mate, these things are usually flash tuned to change things like boost, timing fuelling etc, that is there usually isn't a boost controller or bleed setup. Best bet would be to throw on a boost gauge. Stock boost on a ba should be around 6 psi
  4. Mines been going good for nearly 10.5 years, 7.5 years with a tune and covered 210k km, never been serviced, towed, raced occasionally.......mostly it did the school run lol.
  5. Happy Birthday instro!
  6. Had a similar problem, it ended up being a couple of my coil packs had tiny cracks in them. Good luck getting it sorted.
  7. Happy Birthday instro!
  8. It's a pain in the arse not being able to lock your car. I've had a similar problem on my BA after a fair bit of wet weather. I stuffed around pulling off door trims and mucking around with door actuators but eventually gave up and dropped it into ford. They ended up finding a problem with a loom connector in the passenger side kick panel.....they charged me bugger all for fixing it up even though they spent about four hours chasing down the fault. Good Luck
  9. Happy Birthday instro!
  10. Just got mine fixed, that is a new cable assembly and fuse block assembly all supplied and fitted by ford....cost $245, took less than an hour.
  11. Just read your other thread. Dont know what would be worse, the fact that someone took the cars or the fact they were in your kids house. Hopefully Karma will get them.
  12. that's a bit close to home, thanks for the info. How are they starting the cars? Are they breaking in to get the keys?
  13. Thanks senna T, I gave it a go but the locks didn't go up and down, aaarrrghh! (looked up the manual and you've got to hit a button on your keypad after hitting the reardemist 3 times). I'm guess the cars receiver for the remote isn't working.... feel free to keep your idea's coming.
  14. My remotes have stopped working. They worked intermittently for a while and then stopped all together. I've changed the batteries but to no avail, so I'm guessing its got something to do with the car end of things.......anyone got any pointers?
  15. I hope you keep the write-ups coming, their an interesting read.
