2MUCHKW
2 Neutral
4,125 profile views
  1. What coils are you using BA or FG? What throttle body are you using BA or FG? What intake manifold are you using BA of FG?
  2. Looks great!!! What rim size and offset are they?
  3. Care to elaborate on you personal experience with your Atomic Engine? Quality feedback from personal experiences assists forums member make informed decisions when rebuilt engine purchases have to be made. Not sure why Qik1 wont share his personal experience and what he found upon disassembly with his Atomic engine? Secret squirrel stuff?
  4. Ok ... soooo knowing that "you found what your found" would you ever recommend the purchase of an Atomic engine in the future?
  5. Thanks for the info regarding your decision to use CP Pistons in your new engine. What do you mean when you say "we found what we found"?????? Did you discover oiling issues in your old bottom end as well????
  6. Why the change to CP pistons? Are they a better design compared to the Atomic Cosworth pistons for your application?
  7. Anyone running Atomic's Cosworth pistons in their engine? If so how many km's has your engine done and at what RWKW??? What is the operational noise of Atomic's Cosworth pistons like at idle? Thanks
  8. Hi Ninka, Noticed your running Cosworth Pistons within your Signiture attached below???? What are Atomic's Cosworth pistons like for noise when cold???? 2002 BA XR6 Turbo, ZF 6 Speed Auto, XFT Tuned 371 rwkw, Nizpro Kit, Atomic Rods, Cosworth Pistons, Walbro Fuel Pump, K&N Pod Filter, 4" SMB dump and 5" cat, 2 x 2.5" SS Quad Tip Exhaust, 'Premium' Brakes w. 5000 rotors, Whiteline Anti Roll Bars Cheers
  9. Wow ... not allot of work for an Atomic 968kw rated motor????? What happen to that motor to make you stump up for complete new engine to be built by Tony Bellert Race Engine's?
  10. Hi Bloke, Can vouch for the awesome grip from Bridgestone RE11's ... once they are warm farrkkkkkkk! These things are good in the wet too ... amazing! I have a BF F6 Typhoon with 380rwkw
  11. 2MUCHKW
    401Rwkw
    401 RWKW @ 14psi boost
  12. Wheel Bearing failure on these cars will 9 times out of 10 be due to water ingress! Check Dust Cap for holes and if sound place a small smear of silcone sealant around lip prior to refitting. Water will find its way in if your too lazy to use sealant when refitting the Dust Cap
  13. Wot Dyno Comp ... where n when??????
  14. Hey Senna, Im getting all front control arm bushes replaced this Wed on my BF Typhoon. What L & R Camber and what L & R Toe settings does Wholesale Suspension typically wheel align BF Typhoons too with stock OEM suspension? My car has been badly wearing the inner edges of both fronts the drivers side the worst! Presently my L Toe has been +0.7mm and R Toe has been +0.8mm Presently my L Camber is - 0 54' and R Camber is - 0 56' Presently my L Castor is +7 11' and R Castor is +6 59' Cheers
  15. Ok ... will do bloke. Do you know what caused the damage to the Piston skirts and number 1 bearing in the first Atomic Motor? What did Atomic say when they rebuilt it? Lets know when you have the beast on the road again
