repsolme
  1. ok first thing warzor 1. undo the battery terminals overnight (make sure factory tune in) this resets the factory tune to original. 2. get some wd 40 and remove the hose from the boost soliniod and spray a liberal amount down into the solioniod. leave for half hour and go for a drive and see if power is up, 1. resetting the factory tune to original eliminates the dealer flash if they did one, 2. the soliniod gets dry and sticks requires lubing now and then. this is worth a try as it has helped people on another forum. I guess if it feels more power after trying this you will need to re dyno to see if correct,if this fails take it to reputable tuner. Rep
  2. repsolme
    Bf Xr6t
    yes it is true if it is an 06 build not 05 build I believe someone please correct me if I am incorrect. Rep
  3. well the 3 in xforce sounds awesome and definatley gives better power,spoke to my tuner and it will go on the dyno next week, will let you know how it all goes. Rep
  4. I have just added the xforce 3inch full system with hi flow cat to my bf turbo stock with k&n filter and car runs great however the eng light (MIL) has come on ? does this mean the pcm has noticed the change in the emmisions ? whats the best course of action Rep
  5. Hi Guys I have just got my BFXR6T and want to do the edit ,as my car has only done a few hundred kms im thinking would be good to edit sooner than later, mabye edit now and custom tune when car is run in completely.this way I could return factory tune when it goes in for the 3,000 k inspection?what do you think! Repsolme
  6. repsolme
    Turbo Noise
    Hi guys new to this site - I have purchased a new BF XR6T and collected it yesterday whilst driving around I put my foot down a-bit and could hear the turbo whistle, later on I over took a car and put my foot down and could hear the whistle and then pop and a backfire and loss of power and m.I.L light appeared,took it back to dealer,this morning and a pipe had come off ? anyway drivin this arvo put my foot down and it goes but cant hear the turbo is this normal I thought you should be able t hear some turbo whistle ? repsol
