brutz
2 Neutral
663 profile views
  1. . Sent from my iPhone using Tapatalk
  2. Never ran. Street only. Dynomite performance tinkered with the whole project. Not a problem. On their dyno at 19psi it hit 454rwkw. Flapper ported. Last dyno tune about 4montgs ago. Sent from my iPhone using Tapatalk
  3. I've had a gtx76 for a while. Guessing close to 2 years. Pushing it 454rwkw on e85. No probs. Sent from my iPhone using Tapatalk
  4. brutz
    Zf Auto
    Pressure up. Torque settings turned on. All good. Sent from my iPhone using Tapatalk
  5. brutz
    Zf Auto
    I'm not sure who I should talk to in Melb regarding repairs and upgrades. Any ideas? Sent from my iPhone using Tapatalk
  6. Aim for gtx3576 that's what I have. Your basically doing what I've done. 1000cc injectors. Same fuel pump. Pretty much the same. As mine. I'm pushing 407 on98. E85 has me sitting on 463rwkw. Sent from my iPhone using Tapatalk
  7. brutz
    Zf Auto
    Just left tuners. Might be a solenoid? Thoughts? All gears are fine in auto(auto 2 to 3 flare) manual mode. In manual the flare won't happen if we back off or hold revs for a sec then change. Sent from my iPhone using Tapatalk
  8. brutz
    Zf Auto
    From chatting to a few trans mechanics it basically depends on what's good in the auto and if you want to change the whole lot. I know nothing about these boxes. So trying to source as much info as I can. Can you upgrade clutch plates? Sent from my iPhone using Tapatalk
  9. brutz
    Zf Auto
    Wouldn't attempt. The thing is I'm the type of guy that hears a squeak or knock I drive to the shop. What is it? I ask It that. They tell me. Order it and call me when in. I say. So wouldn't attempt. I know I can put more pressure in the flare which will "fix/bandaid" it. It's only the one gear. At the moment. So I'm thinking whilst it's ok I'll look for a good reco/2nd and spec it up. I've got sct flash and xcal4. So tuning isn't a drama. So thinking change shaft. I don't want to spend heaps. Just the minimum plus 20% to cover the horses. Sent from my iPhone using Tapatalk
  10. brutz
    Zf Auto
    I've found Nizpro just puts down a lot of guys out there. I was looking into CMS. GREGO77 want should I be budgeting for?? Sent from my iPhone using Tapatalk
  11. brutz
    Zf Auto
    One more question. I'm looking at a reco zf. $3200. Comes with w'ty.before I get installed what are the mods do you think I should do Sent from my iPhone using Tapatalk
  12. brutz
    Zf Auto
    Womend what have you done to your trans Sent from my iPhone using Tapatalk
  13. brutz
    Zf Auto
    Understand. But! If I could turn power down Nd replace clutch just to keep car going till next year. That way I save for an upgrade. Sent from my iPhone using Tapatalk
  14. brutz
    Zf Auto
    Zf are new too me. Can't you replace clutch plates? Sent from my iPhone using Tapatalk
