BFHOON
Everything posted by BFHOON
  1. hi mal I want to ask about shift kits for the t56 can I change the shift pattern from h to up and down like sequential style
  2. You can get a WOGCOOLER for less than $500, can't you? ← I believe for $480. So has anyone actually tried and sourced a Typhoon cooler from FPV directly? ← Yep, that's how I got mine. Supplied a VIN, handed over lots of $$$$, got me a F6 cooler! Cost me $1290.00 ← and now its on my t
  3. I will see u all at the warrick farm after 1200 cant make the cruse will be fitting new cooler
  4. I ment get the injectors fitted by the tuner
  5. whats the adresse for hooters
  6. I agree jack custom tune is the way to go I will put on the cooler then generic 8 psi then possibly get injectors with the tune to finish it off. its a bf so I have been told the springs are ok and already has a t56 so mabee a cluch will go in also. should make a sweet ride
  7. no probs pm sent I was also thinking factory ford bits just think. I go in for service the guy says hey mate u got a bigger intercooler I say its factory no probs
  8. not at the moment scotty but all I did was post a thread that I was after one and 1 day later whalla
  9. hey guys. I have a question for you educated peoples out there. I have got my hands on a nice polished f6 cooler. has anyone out there put one on there t without a tune.,I mean stock not a retune. will it be ok to mount ot and drive it easy for a few weeks till I tune the beast. and will the generic 8 psi tune work ok with this. I know the best thing is a custom tune but im doing this over time so as to spread the cost.
  10. and I thought a turkey slap was when u pull up next to a na xr6 and do the turkey gobble on a gear change as u wheelspin past him.
  11. my mate at work has a s4 rx7 with a 10 second doweled turbo 13b running 8psi he ran a 14.8 after he tunes it he says he will do better. the motor will take 20 psi. the gearbox will not
  12. verry interesting was it a ba or a bf. I have heard the bf is detectable
  13. BFHOON
    Wsid
    I work 1k from wsid and it pissed down all day I think its still raining now
  14. BFHOON
    Wsid
    I will be there in case u need a lift home max
  15. DBOSS is the Sydney cruise organiser. He can usually get renta crowd together for some (quote) fun with saleens mum
  16. if u guys are interested you can send me or bring in a 100 ml sample and I can give you a 0.1 %accurate alcohol reading I run a testing lab
  17. I have seen a 6t the same colour with the same stripes cruzing minto maccas
  18. I forgot to turn off the tc and ran a 15.3 then switched it off for the next run and got a 14.6 that's proof
  19. BFHOON
    Flash Tuners
    im ready to go with a capa box new 895 and custom tune 400. I think this is a good price what do u guys think
  20. Anyway, the engine is in for a full re-build with argo forged H-beam rods / rod bolts, forged pistons, hardened crank, etc, plus a full blueprint and extensive machine job. Nizpro are doing the work and the engine will be able to support 500 rwkW without problems. The aim is to take power to above 400 rwkW of nice streetable power. Cheers Robin. I have heard they also add a girdle to make the crank one with the block to stop flex
  21. id like to see liberal in power with an equal senate so its not open slather for them.
  22. to use kim bumblys words. THEY KNEW BUT THEY LIED TO THE AUSTRALIAN PEOPLE. how many times has howard been caught out telling fibs. yesterday he said there was no deal now theres some doubt. I dont buy it
  23. thanks guys I will look into the interface box. the shift light is a gismo and has a launch control box that takes signal from the shift light once I get the box and mount the clutch switch I will have programable launch control with anti lag and flat shift. im not sure how this will be hooked up to the ignition it has 6 in and 6 out from the launch controll box for multi coil control but u can use 1 also. it runs on throttle cable systems by misfiring the coils but im not ure how this will work with the fly by wire system. im going to talk to a tuner and try and get it all hooked up with a custom tune.
  24. I have a stand alone shift light that needs power earth and tacho signal. the power is a no brainer but how can I get a tach signal to send to the shift light. any opinions would be appreciated.
  25. mcguires seem to be the best and they have a pretty impresive range. I picked up the clay kit today 30 bucks it has a slab of clay and a spray on lube used together they get pretty good results a friend put me on to it he uses it on his suv what do u guys think
