BFHOON
Everything posted by BFHOON
  1. his name was robert paulson
  2. BFHOON, are thos billet pipes? the pipes I have are high grade extruded alloy polished up and supplied by plazmaman. totally smooth inside with no welds. if u look at the plazmaman under battery pipe you will notice no welds.
  3. heres the deal right...... dont tell anyone. get some bog,nikky what ever u want to call it. mix it up and get a tiny bit on your finger and wipe it in the chip and wipe it over with your thumb removeing all traces of wet nikky of the paint around the chip using your thumb, the oil from your skin will remove all trace leaving bog in the hole. paint over the bog with the touchup paint.
  4. BFHOON
    Best Beer
    for me its a ice cold haagen fresh off the production line at 630 am... then at 730 and 830 and so on untill I stagger home at 3 pm........
  5. iv always loved rick bros nkotb insink and boys 2 men
  6. this one can be easily added to the rips patches fooly sick mods thread.
  7. so do people from the gong cruze to sydney same as us sydney siders cruze to the gong.
  8. now the logo says monsta instead of monza
  9. BFHOON
    Apec Sucks
    it would have been cheaper and easier to have it at hamiltom island. just add a few aussie war boats and choppers for security, no protesters they can all go scuba diving and eat prawns saving us taxpayers millions. 300 mill would have been a greatly needed boost to the public education system or possibly even pay for some medical reaserch,,ect.
  10. I would say go the injectors custom tune and the clutch. if you can squeeze valve springs in get then too. this will keep u happy and will mate well with the zorst u already have. then later go the cooler and wheels. you will be sewing spending all your moolah on go fast and have your clutch say no way. or do 2 stages on the car. save up and get cooler pump injectors valve springs custom tune and clutch. then later on get the wheels and guages and lowering. better to only get one custom tune rather than 2 or 3.
  11. BFHOON
    Apec Sucks
    kevin07
  12. its not really a case of what boost pressure it stops at, if the computer senses that it cant alter the boost on a percentage of times calculated on a scale it says ,no thanks, it uses 2 boost sensors and many people have tried to fool the computer. I have read articles from back when the t first came out saying that you can get away with a few psi using 2 bleed valves but the computer still figured it out and said no after the secondary system picked up more power from the gearbox torque tags.
  13. BFHOON
    Apec Sucks
    I heard the chaser <comedy show> got some hummers and had a fake motorcade today and got past 2 check points and a guy dressed as osama binladen hopped out and was arrested real quick it made 2 years of security planning look like a kids birthday party.
  14. yes but it didnt effect goey joey...lol
  15. hope this helps...... Detonation/pinging creates extremely violent combustion shock loadings, as the actual combustion process is completely transformed in nature from normal combustion. The easiest way to explain the differences between "normal combustion" and "detonation combustion" is to imagine a small amount of petrol is poured along a flat surface, and then lit. When it is ignited the flame runs along the line of poured fuel, gradually lighting it all along the way. This is how "normal combustion" takes place in the engine. The air/fuel mix is ignited by the ignition source and the resultant flame propagates across the combustion chamber, consuming most of the fuel/air mix along the way. Combustion pressure pushes the piston in a downward motion and this vertical movement is turned into rotating motion by the conrod and crankshaft. By comparison, "detonation combustion" is like an instantaneous explosion in the combustion chamber, rather than a controlled burn that builds cylinder pressure gradually. The explosion is like dynamite going off in the cylinder, with huge cylinder pressures blasting out in all directions at once. Everything in the combustion chamber is smashed into by this force, cracking pistons, hammering the piston rings, shattering spark plugs and, in the case of XR6-Turbos, bending/breaking the conrods.
  16. if your looking for a xover and a pipe from your pwr cooler the plazmaman stg 2 piping kit should fit. looking at this pic the pipe from the cooler can be shortened to fit the pwr and its the same size from the cooler to the tb. you have an airfilter already so you only need one part of the kit. they also have a hot side kit from the turbo to the cooler and looking at the similar size of the pwr cooler to mine, it should fit too. hope this helps.
  17. I can picture how it happened, the cleaning lady would have seen it and said. I aint touching that and closed the door. the thing that supprised me was its size nearly a foot long and round like a chicken loaf. we rang the manager and said quote some filthy bugger has backed out a big terd in the shower andi aint cleaning it up, I want a nother room. they obliged with a better room.
  18. less than five minutes.
  19. geez that would make one hell of a trade in.
  20. if you dont have tints mal the photo from cackling pipes will show the baby seat in the back as the res of his pics that you buy is huge. that would be a funny photo. I just purchased a 4x4 myself not anything quick but I have plans to turbo charge my rav4....lol iv already put on auscar rims and 20% tints.
  21. this is from today... not mine. from the crew board. I edited the swearing only not the incoherent bad grammer. Posted by: BattleAxShrew Subject: good hate mail to my pal From: LegionerNr17 To: REALxPITA Date: 09/2/07 9:54 pm Subject: [none] u peas of s..t I promise u that I ll spent the rest of this round, every turn in this round to beat the sheet out of your stupid head u motherfu..er, ohhh boy your ass is my !!! lol
  22. its mostly, your gay and im going to kill you and I know som one who will destroy you. funniest thing is indian people who call you a bastard guy with limited english.
  23. while we are airing dirty laundery. thompson ford seems to think the only way to fix a leaking timing cover seal is to smear a big finger wad of gasket goo on the oily dirty engine block. I went out of my way to get the car to them for 2 days <because I know its sump off big job> and he calls me the next day saying its ready only for me to find it was still leaking and the forementioned gasket goo smeared everywhere, like a 5 year old kid did it. I swore never again and voided my warrenty with mods............fraud service......
  24. im interested in who is building your donk and how much it is costing you. we will hopefully catch up soon and have a chat as im going down the same path and am in a similar location. as for the paint you dont really need to sand it just make sure its clean.
