BFHOON
Everything posted by BFHOON
  1. I have this spa and I want to put a heavy extention lead into the power board on the spa as a temporary hookup untill I get somone to install it properly. the rating is low enough for a lead and I have a safety switch. heres a pic of the imput, any help would be appreciated.
  2. yep that's the full 1/4 none of this 8 mile nonsence here.....
  3. to answer your question the stock injectors will max out at around 9.6 psi. 10 pounds will be about the max you can get away with without getting bigger injectors.
  4. you sure can do a soft cut senna. if you give yours a try being from the same tuner as me it should give a smooth pop pop pop as mine does. none of this head on the steering wheel stuff, I noticed the hard cut on my dads fpv persuit ute fark its a real party pooper.
  5. iv heard there will be a carshow/fundraiser for lukemia lunch or somthing like that to help out the kiddies with cancer TONIGHT at harrys cafe liverpool. im told its a gold coin to put your car with the expected hundreds of fords and holdens and ricers. there will also he provisions to shave a de head or spray it colours. it may be worth a cruse up this way to check it out see the cars and have a perv on those hot asian chicks with the short short skirts.
  6. I can vouch for this stuff. its reverse engineered alien technoligy stolen from area 51. this stuff is what the aliens use in there protien powered particle accelerators to provide a friction free path for neutrons to spin at twice the speed of light. the protiens are extracted from the red cross who are really owned by the aliens, they use the human blood plasma to power these protien powered accelerators so as to produce anti matter that is projected in front of there space ships so as to produce an antimatter vortex slipping the space craft into a hyperspace situation. I suspect that the aliens have infultrated the inner workings of the internet so after I post this I may never be heard of again.
  7. I think that 9 second car had the .70 aspect ratio compressor housing. basicly stock with a few mods.
  8. i have dannys ones they said deka on the side.
  9. id say get it looked at by a mechanic. its not a big job, some of the guys here can change them at the track with a jack and some tools.
  10. there is vids on here of a guy fitting a nos kit to a lawnmower then he destroys watermelons and trees.
  11. beck home in nz you can jist go to the local shop to get some hid lights bro.
  12. IMPACT. KEVIN O7
  13. im into electronics max, it may be the case that if you put a variable resistance attenuator inline with the sensor you can adjust the signal from the sensor to the icc and make the ac system think its 50 degrees outside.
  14. if you use a 3 or 4 position switch with position 1 being standard you could select p1 and use the aircon, and only use the other ones when testing the air temp. you dont really use the aircon when driving hard do you.
  15. it may not just be a case of getting any old sensor. you may have to round up some stockies from wrecks. but I would say its a great idea.
  16. depending on where you go it can cost between 350 and 900 dollars and between 2 and 6 hours.
  17. if you look at itschriscrockers profile there are a few other vids confurming his gayness. titles like why im gay and if I were miss universe. he will have a tour of all the talk shows in the usa now and will make a mint over this...lol
  18. its not really advisable to drop the clutch at those rpms. unless you want to be looking for some new cv`s also.
  19. ooohhh year the muzzter in a g string doin that pole. better make sure its mounted properly.
  20. 15 would be good ....your motor will handle it.
  21. a simple check to find out what boost level the actuator is would be to remove the boost control solonoid and join the 2 hoses together with a metal pipe. then go for a drive and record the max boost level.
  22. if it had been to ford they definatly never replace the xover properly. I would say for sure its the xover loose or folded over underneath.
  23. just go easy on it dont soak the fins in paint.
  24. I have ordered a car bra to cover up all my chips
