BFHOON
Everything posted by BFHOON
  1. id be looking at the crank angle sensor. throttle position sensor. fuel blockage as u said. possibly the solonoid wd40 job any vacum leaks blocked cat from added heat from the edit. bent rod, a bit extreme, hows the idle rough, theres so many things it could be, good luck mate I hope u find the problem. have a try at removing the battery over night.
  2. I can hook u up bro :banghead:
  3. not the water rates,,,,, the intrest rates u know the reserve bank.
  4. I would say yes its a full reset. there may be a second chip not associated with tune holding memory such as times dates and other tid bits.
  5. what they have lifted is the intrest rates again. just slap a nother .25%on it sheel be right.
  6. the f slot has the factory tune and is only loaded once into the box on the first use of the flash box. if you want to add new data to the f slot you need to reset the flash box and loose one life. if you had a car that had a performance tune in it and the box was not sold with the car, when you put on a new flashbox it will load the perfoemance tune into the f slot. the f slot dosnt do what your saying it wont hold any old settings in it.
  7. no mate its a full reset on the f slot. it cant be overwritten and dosnt save anything extra to the f slot.
  8. cant make it senna I have plans.
  9. no tricks senna just havnt seen u there yet. I use both minto and blaxland rd oftern.
  10. hey senna, do you use the pay and spray at minto or cambo central.
  11. I heard on the radio that we can wash our cars with a trigger hose now.
  12. you do.
  13. yep done that, I couldnt handle the wingeing of the teen gf and the wingeing of her mother too. ahhh the wonder years.
  14. its all the good deals and quality service from sinclair ford.
  15. I would say its a wrecker mafia thing. if several wreckers were hit in one night in one area its a bit sus.
  16. I know for a fact that (plazmaman) alex and oyay are working till 12 and 1am most nights to keep up with there current workload. I doubt that they will have any spare time for a few months.
  17. Driving on our roads is a privilege not a right. Driver identification is critical, not only to the offences regarding road safety but also relative to criminal activities, public order and homeland security. so who elects the pedestrian council? is scuby the only member? is this *beep* being payed by the government?
  18. 7 hours and the jobs done. not too bad as it took half a carton of wild turkeys.
  19. as the others said in the other thread, yes this box can totally tune your car but you cant do it a capa agent/ tuner can adjust the settings allowing more boost and more power. just plug it in and have a go. if anything goes wrong we can talk you through the process of getting the f slot back in.
  20. getting to instructions. reds off plug in the box to the plug near the fusebox. select p1 p2 or p3 with the select button and press the program button. once the box starts flashing turn on the reds and wait till the program light holds a solid on light. the f slot has your factory tune in it and must be replaced before ford look at the car. your car may have a custom tune already installed but as the others have said you may have generic tunes loaded in the box. the edit cant remove km`s from the odometer.
  21. ok,
  22. after this cooler and zorst goes in its time for an ? bottom end and exchange rear housing with bigger flapper and actuator. and the build costs. ? surge tank with twin 044`s. ? valve springs. oil pump that ? gurdle/splash pan geez I know what u mean there senna, its a big list.
  23. only 2 days till my car gets the plazmaman treatment again. im looking forward to getting this next stage of mods done and tuned. then its on to stage 3...?
  24. nothing to worry about, just some thunder and light drizzle. that's in the south west of sidunee.
